Horn Blowing in Cold Temperature
Old Jan 5, 2015 | 07:55 PM
lgabb's Avatar
My '06 TL has spent most of its life in the warm Southeast. Currently in Colorado Springs, the horn started blowing continuously in the wee hours of the morning while parked outside in 6 degree temp at a rented condo. The neighbors and subsequently, the police were not amused. This was not the alarm as the horn was blowing continuously and the lights were not flashing. Pressing the steering wheel would momentarily silence the horn but it would start back after a few seconds. Had to disconnect the battery to silence the horn. Reconnected the battery several hours later when it was nearly 30 degrees and everything was OK. Any ideas? Don't want to have to take the horn fuse out every night. Also, where is the horn relay located?
Old Jan 6, 2015 | 08:20 AM
Adobeman's Avatar
The DVD-A Script Guy
Check you PM inbox. Could be the relay, horn switch or cable reel.
Old Jan 6, 2015 | 01:41 PM
FlyinLowTL's Avatar
Ill bet its the horn relay - old relays have a tendency to 'hang-up' in the closed position when they are NO (normally open).
rcs86
Aug 2, 2016 06:52 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
hashbrown
Sep 29, 2015 12:13 PM
