Horn beeps when starting
Old Aug 28, 2008 | 07:22 PM
stevey678's Avatar
Anyone knows why my horn will beep two or three time (short beeps) when I start the engine? It started after the B1 service on the MID came on. I've read through the manual and it does not mention anything.
Old Aug 28, 2008 | 07:27 PM
playa4real's Avatar
take ur other hand off of the horn when you turn the ignition on
never heard of this happening. is it every time or just occasionally?
Old Aug 28, 2008 | 07:29 PM
stevey678's Avatar
Hands are off the horn. Everytime when I start. Car is going in for service this Sat.
Old Aug 28, 2008 | 09:57 PM
csmeance's Avatar
that is odd, I think a bare wire might be touching a ground or something...
Old Aug 28, 2008 | 10:40 PM
Will Y.'s Avatar
Registered but harmless
Do you have an aftermarket alarm? If so, that's where to start looking. If not, .
G/L.
Old Aug 29, 2008 | 01:59 AM
TLType-s12's Avatar
TL-S izdashiznittt in
AFTERMARKET alarm.....<----- there is no other logical solution. My friends cars horn beeps twice and 3 times if he autostarts it
Old Aug 29, 2008 | 07:46 AM
stevey678's Avatar
I'll know tomorrow after the dealer gets to look at this. No aftermarket alarm. Alarm came with car. No mods done on the car, so I think it's possible that it is a wiring issue.
Old Aug 29, 2008 | 07:47 AM
Trew's Avatar
loose wire inside the steering column where the key tumbles. try keeping the key at the exact position where you hear the horn and see if the horn stays on.
Old Aug 29, 2008 | 07:49 AM
stevey678's Avatar
Trew, tried that already. Even tried to leave the key in the ACC position, and the horn gave two or three quick beeps. This is very wierd.
Old Aug 29, 2008 | 08:11 AM
csmeance's Avatar
you may have a bad alarm unit where the car forgets that it unlocked itself and when you turn the key on, the alarm then realizes ok, doors unlocked, and it turns off the alarm.
Press the panic button in the daytime when not to many are around, the horn will scream loudly, see if that's the same sequence of beeps with the same timing as that 2-3 quick beeps.
Old Aug 29, 2008 | 10:44 AM
stevey678's Avatar
csmeance, I did try that yesterday. Pressed the panic button, but it not the same. the three beeps the horn makes is very soft, compared to the panic button alarm.
Old Aug 29, 2008 | 11:02 AM
LoveMyTL-S's Avatar
I wonder is the number of beeps means a certain problem. Much like the beeps a computer will make to indicate some is wrong. The number of the beeps corresponses to the problem. Or perhaps your car is just happy to see you........
Old Aug 29, 2008 | 05:39 PM
stevey678's Avatar
I just dropped the car off at the dealer. Service advisor never seen this problem before. They will look at this issue and also do the B1 service. I'll let you know the outcome of this wierd problem.
Old Sep 2, 2008 | 10:36 AM
stevey678's Avatar
well, got the car back. Dealer informed me that there is an aftermarket alarm system in the car, but it was never activated, since I never purchased the alarm system. It seems that the microswitch under the dash was defective.
rockyboy
Aug 4, 2024 10:35 AM
obert
Dec 14, 2015 11:36 PM
Azonics
Sep 22, 2015 05:28 PM
Phambam12
Sep 6, 2015 06:57 PM
