High pitch squeal/squeak?
Old May 2, 2012 | 02:50 PM
wsudu's Avatar
Hi everyone, I searched but couldn't quite find what I was looking for. I have an '06 MT TL with 75K miles. When I start the car, I can hear a high pitched squeal or squeak pulse about 10-15 times per second. I thought it was a belt but now I noticed that when I even just barley push (about 1 inch) the clutch in, that it goes away. It does change with the RPM as well. So I'm wondering if it is the clutch or just a squeak somewhere that a slight pressure on the pedal is muffling. Any ideas? Thanks
Old May 2, 2012 | 02:55 PM
SharksBreath's Avatar
BANNED
power steering hose? have you had the o-ring replacement done? does it happen when you turn the wheel? how does the fluid look in your PS res? full, empty? notice any leakage on the hose?
Old May 2, 2012 | 02:56 PM
wsudu's Avatar
It was done a long time ago and the fluid looks great without any leakage. Thanks Though
Old May 2, 2012 | 07:13 PM
Ccvn0's Avatar
Replace new belt
Old May 2, 2012 | 10:44 PM
wsudu's Avatar
Originally Posted by Ccvn0
Replace new belt
But thats what I'm saying, it's not the belt.
Old May 4, 2012 | 09:29 AM
wsudu's Avatar
Anyone? Here, I posted a video of it. Sorry for the bare feet (you know some people hate feet) but I'm too lazy to reshoot it. You can hear it immediately then when I press on the clutch, it goes away.
http://gallery.me.com/wsudu#100195
Old May 4, 2012 | 09:36 AM
BSpecialist's Avatar
Pretty sure squeaks that go away when pushing in the clutch are usually related to the throw-out bearing. I assume the TL has one? Someone feel free to correct me if I'm wrong.
Old May 7, 2012 | 03:14 PM
wsudu's Avatar
Anyone else? I figured a ton of people would know about this but I think since the thread had been moved it keeps getting looked over.
Old May 8, 2012 | 09:09 AM
dc2_LEO's Avatar
This. Throwout bearings will go out. I haven't heard one squeak before, but there is that possibility. They usually make an ugly low grinding noise. It makes most sense because the noise goes away when you press down on the clutch and it changes with RPM.
Old May 9, 2012 | 05:22 PM
Wilb82's Avatar
WDP 05' TL 6MT Navi
Incredible, my 05 6MT with 96k has been making a pulley squeak sound for the last few weeks and was worried it was something with the timing belt but the sound was not coming from that side of the engine, after reading this post just now I ran out and tried putting the clutch in and sure enough, the squeak went away. Can any one else confirm that the throw out can squeak like that?
Old Aug 20, 2012 | 05:04 PM
slaMmed V6cOupe's Avatar
6th Gear
bump can someone confirm the sound of a throw out bearing having the same issue
Old Oct 17, 2012 | 12:48 PM
c_potvin's Avatar
I have this problem too.
-Start by applying grease between the tip of the slave cylinder and the release fork. This may be caused by the end of the release fork vibrating.
-If this doesn't solve the problem, it's probably the release (also called throw-out) bearing.
Carl
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
San Yasin
Sep 29, 2015 10:52 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
