HIDs are crap!!!
Old Sep 15, 2011 | 12:04 AM
ACURA UNDERGROUND's Avatar
4th Gear
HIDs are crap!!!
My drivers side HID went out,i replaced the bulb.When I turned my lights on they both worked,but there was a buzzing coming from the driver side i just replaced.The buzzing went away,but when I put inner fender lining back in and rehooked the battery back up and turned the lights on,the light i replaced was not on???What could the problem be???Also my high beams(inner lights)dont work.Please somone give me some info on these issues!!!!
Old Sep 15, 2011 | 12:17 AM
Bearcat94's Avatar
AZ Community Team
Bad ballast?
You should usually replace bulbs in pairs. And it's better to use high quality Phillips bulbs. FYI;
Old Sep 15, 2011 | 08:45 AM
tufino1128's Avatar
I also replace mines and my drivers side high light wasnt working so i check again and theres one plug that i forgot to conect its on the bottom part of the headlight cover when i plug it back my light was working and the sound its normal i could notice on mines too thats normal .
Old Sep 15, 2011 | 08:53 AM
john_wrap's Avatar
[Mod Censored Title]
Originally Posted by Bearcat94
You should always replace bulbs in pairs. And it's better to use high quality OSRAM CBI bulbs
Fixed
Old Sep 15, 2011 | 03:22 PM
csmeance's Avatar
Always replace bulbs in pairs and also do some trouble shooting before throwing parts at the problem.
Take the old driver side bulb and try it on the passenger side, does it work? If not then the bulb is defective. It it does work then the problem is the igniter or the balast on the driver side. Swap the parts from the working side and see if it fixes it.
Old Sep 15, 2011 | 11:29 PM
jimmyl's Avatar
Plastic schmastic
HIDs are crap!!!
My HIDs don't appear to be crap. It might just be yours!
Just sayin'.........
Old Sep 21, 2011 | 07:34 AM
05TLbase's Avatar
the "inner lights" 04-06 are the fog lights... turn those on and they may work if your high beams are off, def wont if high beams are on
07-08 "inner lights" are daytime running lights and will be off no matter what if your headlights are on
The high beams for the HIDs are just a flap that allows the beams of light highter than normal headlight operation.
hope this helps
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
