HID replacement
HID replacement
I have already gone through the hassle of replacing my hid bulb, but now that will not work. My DRL have power. What would be my next option , replacing the ballast? Not really sure where to go from here because I replaced the bulb correctly t my knowledge.
Take parts from the WORKING SIDE of the car and swap them to the non-working side ONE AT A TIME until the problem is fixed.
I'd swap the ignitor first from the working side. If that doesn't do it then swap over the ballast!
Remove your front bumper, take your time and you'll be fine Be sure to wear gloves when handling bulbs, and make sure that everything is seated firmly and securely.
benny_jdm
01-31-2016 06:15 AM
