Hid help
Old Oct 31, 2011 | 09:57 PM
Phambam12's Avatar
Phmbm12
Hid help
i bought new bulbs after one of my D2S bulbs went out and replaced it. it wont turn on! then i noticed theres condensation in the headlight so i baked it and redid it. so is it my ballast or the wires or what.. i need help
Old Oct 31, 2011 | 10:10 PM
gogators22's Avatar
I heard it may be ignitor or a loose connection or a bad ballast. Try switching ballasts to troubleshoot first.
I'm not sure where the ignitor is or where to buy one tho.. wish I could see a pic.
Old Oct 31, 2011 | 10:14 PM
Imabeast31's Avatar
the ignitor is the wire that runs from the ballast into the inside of the headlight it actually holds the bulb... switch ballast to the opposite side to troubleshoot, if thats not your problem do the same thing with the ignitors. You can easily unplug the ignitor from the ballast just lift up the rubber piece around the top of the ballast you should see the connector. More than likely its the Ignitor. Wouldnt hurt to check the bulb too while your at it.
Old Oct 31, 2011 | 10:17 PM
Imabeast31's Avatar
If all this yields no result each headlight has a ground that is mounted to the frame of the car ( follow the wires).. wouldnt hurt to make sure your still getting a good ground on the side not coming on ... Correct me if Im wrong but im pretty sure im right.
Old Oct 31, 2011 | 10:21 PM
gogators22's Avatar
ooooooooooooohhhhhhh I may need to get on that.. Ive removed the headlight twice at night so maybe I unhooked it
Old Nov 1, 2011 | 11:16 PM
Phambam12's Avatar
Phmbm12
i dont know how to take the ballast out. its not the bulbs because i got a brand new set. i'm getting a headache.
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
