HID Bulb in Fogs Not Lighting
Old Nov 20, 2016 | 10:13 PM
gopeman's Avatar
Hello all! I have a 2008 TL (non-navi, base) and I installed the Opt7 35W HID kit into the fogs. The passenger side lights up bright and right away, however, the driver side doesnt light up sometimes, and I'd have to turn the fog lights on/off a few times for the bulb to start lighting up. I also noticed that the drivers side bulb is way less bright compared to the passenger side. Any ideas on why this is happening?
Old Nov 20, 2016 | 10:20 PM
Ballast is going bad on the driver's side. To confirm swap the sides to confirm
Old Nov 21, 2016 | 06:21 AM
he bought an aftermarket kit to install in the lower fogs.
OP, did the aftermarket kit come with a relay?
it's important to install a relay, so you wont get issues like this.
Old Nov 21, 2016 | 01:27 PM
truonghthe's Avatar
^^^what he said, but even with a relay it can be problematic sometime especially it rain for long period time. I had TRS morimotto 35w kit along with their relay harness and the ballast keep blowing out, I had switch to LED bulb and never had any problem since.
Old Nov 21, 2016 | 05:56 PM
gopeman's Avatar
No the kit didn't come with a relay. Is installing a relay fairly easy? Also, have any of you guys heard any success of an HID kit without a relay on the the 07/08 models? I'm thinking if it'd be worth replacing the ballast or just save up and get some good quality LED bulbs. Thanks everyone for the help too!
Old Nov 21, 2016 | 06:02 PM
relay is easy to install
www.theretrofitsource.com
LED won't be as bright but definitely doable without relay if you prefer. up to personal preference really.
Old Nov 21, 2016 | 10:26 PM
gopeman's Avatar
Are you recommend the HID/LED kits from that website? Sorry, just confused haha
Old Nov 21, 2016 | 10:59 PM
Yeah and/or the relays there are top notch as well.
Old Nov 22, 2016 | 08:26 AM
truonghthe's Avatar
if you gona do LED fog please don't be cheap, I paid $120 for my set and it def worth the cost. Bright as my HID but less glare than my HID.
Old Nov 22, 2016 | 01:22 PM
gopeman's Avatar
Which LED kit are you running?
Old Nov 22, 2016 | 01:28 PM
truonghthe's Avatar
Option 7, it was $120 like about year and half ago but now they only at $80-$90. Here is the link
http://www.ebay.com/itm/141626730616?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Nov 23, 2016 | 03:46 PM
eastcoastguy's Avatar
I went with these H8 XML2 LED (pair) - H8 - LED Bulbs - All Products should come next week so I will review them then. 3 year warranty, only ones I have found that provide option to match OEM HID and realistic lumens that should still be plenty bright.
Dquackers
Jun 24, 2022 11:04 PM
juice13
Feb 11, 2021 10:42 PM
Confusednewb
Nov 16, 2016 02:13 PM
Eggs999bacon
Mar 18, 2016 09:36 AM
Skirmich
1/2G MDX (2001-2013)
28
Feb 8, 2016 03:38 PM
