Hesitation in VTEC, flashing check engine light
Old Aug 22, 2019 | 09:07 PM
WhyteLegend's Avatar
It seems when the car gets into VTEC the RPM hang/hesitate then I get a flashing check engine light..
Random misfire
I am unable to upload a video format shows to be mp4.
07 TL-S / manual
New OEM NGK plugs,
New VTEC solenoid
Did all the resets suggested after searching the forum..
Issue with the set of OEM or NGK coil packs
Entire head was serviced and exhaust valves replaced
Due to an engine overspeed when upshifting.
Old Aug 24, 2019 | 02:33 PM
Does the timing also looks off ?
Old Aug 26, 2019 | 02:39 PM
LoveMyTL-S's Avatar
Anyone?
Old Aug 27, 2019 | 11:45 AM
El_Cheapo's Avatar
What codes are you getting?
Old Aug 27, 2019 | 01:26 PM
Ken1997TL's Avatar
Silly question, how's the oil level? It will not engage VTEC if it's too low.
Old Sep 16, 2019 | 04:07 PM
Misfire random
Oil level is good the oil was just changed
Old Sep 16, 2019 | 05:46 PM
What do you mean by "Issue with Coil pack"?
Old Sep 17, 2019 | 01:47 AM
this CANT be. on UP SHIFT's, the computer protects the engine by cutting the injectors at rev limit...
HOWEVER, on DOWN shift's, there is no protection and you will mechanically over-rev the car.. ie; piston's kissing the valves.
ask me how i know...
LOL from experience...
I mechanically over-rev'ed by down shifting into 2nd from third at 80mph.
the pistons hit the exhaust valves.
Old Sep 17, 2019 | 09:31 AM
t-rd's Avatar
Cannot determine if the timing is on if you don't also show the mark on the crank pulley, the white mark on the edge of the crank pulley should line up with the big arrow on the lower timing cover also.
And read the pending codes using an OBDII diag device since you received flashing CEL. That'll determine what's going on.
Old Sep 21, 2019 | 07:55 AM
I replaced all the coil packs since I was told it could be the problem
Came off the clutch too quick and stumped the gas in neutral , saw RPM it about 8k was attempting shifting from 3-4.. coould have been the same as you it happened so fast
The odd thing is I had the heads removed sent to a machine shop ( all exhaust valves replaced ) , guy states the Pistons looked good no visible damages.
The reading seems to be inconsistent from what I have been told, difference when car is cold and warmed up..
This sucks
Wish I could upload the video
Jason46
Aug 10, 2019 01:54 PM
Bigtrav
Nov 6, 2017 06:49 PM
chavp
Integra
Mar 5, 2015 10:17 AM
CLassy
Sep 21, 2005 11:21 PM
Aston_db4
Jul 1, 2005 12:28 AM
