Helppp!!! APP SENSOR REPLACED WITH NO HELP!!
Old Jun 6, 2016 | 09:34 PM
njresendez's Avatar
APP SENSOR has been replaced today and my Acura 2006 TL will not accelerate it will only drive about 15 to 20 miles an hour it actually starts off in 2nd gear and will not go into first the cable is tightened and it feels as though the title is not getting enough power to this be a fuse of some sort? I was fixing a short that came from my AC compressor that cause my windows and wipers and gauges to go out after that was fixed that's when the acceleration pedal would not let me go fast anymore immediately after that. I don't know what else to do please help!!
Old Jun 6, 2016 | 10:19 PM
Hi speed's Avatar
runnin a little boost
Have you reset the ECU?
Old Jun 6, 2016 | 11:00 PM
njresendez's Avatar
Yes I did just now 3 times and my vehicle still will not accelerate! I will say I have just recently put on a jpipe and pre cat delets as well would that cause it?
Oh and are the ore cat deletes supposed to look RED HOT??
Old Jun 6, 2016 | 11:11 PM
nfnsquared's Avatar
Dude, get the codes read....
Old Jun 6, 2016 | 11:45 PM
njresendez's Avatar
codes
well i actually did earlier today and it said i had an error for not getting enough power to the APP sensor....and one other for my 02 sensor which i just figured it was from the pre cat deletes and my ATLP j-PIPE I INSTALLED 2 weeks ago.
tomorrow i will read the codes again, and post them and HOPEFULLY I CAN FIND THE issue. sucks not being able to drive my car petal to the floor lol!
Old Jun 7, 2016 | 10:50 AM
njresendez's Avatar
CAT DELETES Fire red color!
ok so... update on the situation... bout to post the codes that popped up. but one thing i noticed is that last night my CAT DELETES were REDDDD HOTT.... is it running too rich? is it possible that the car is going into some kind of SAFE mode.... and wont let me accelerate past 3000 rpm? please if anyone knows anything feel free to reply THANKS AGAIN!
Old Jun 7, 2016 | 11:20 AM
we can only go off the info you give us and you havent gave us anything concrete....
post the codes for the 4th time
Old Jun 7, 2016 | 11:50 AM
njresendez's Avatar
codes
i have also mentioned in my posts that i would post them shortly.... figuring any info may help..
here it is..
U0107 - LOST COMM. WITH TROTTLE CONTROL MODULE
Old Jun 7, 2016 | 11:57 AM
u0107 - AcuraZine Community - Threads Tagged with u0107
Old Jun 7, 2016 | 11:58 AM
check the blinker fluid?
Old Jun 7, 2016 | 12:31 PM
nfnsquared's Avatar
Bad battery?
Old Jun 8, 2016 | 06:53 AM
after I read these threads, I came to the conclusion of....
Bad battery?
bad battery.
Old Jun 8, 2016 | 06:54 AM
or rat/mouse ate some wires.
Old Jun 8, 2016 | 01:36 PM
njresendez's Avatar
Battery
OK so, I took three battery to auto zone and sure enough.....it's bad... going to pop a new one on and see what happens
Old Jun 9, 2016 | 10:33 PM
csmeance's Avatar
cats should never be glowing red hot, you have a big problem...
Old Sep 30, 2019 | 05:57 AM
fr33spirit's Avatar
would you mind telling us what ended up being the prob with your car? I've got the same code and can't for the life of me figure this out!! I managed to track down a manufacturer flow chart for diagnosing the U0107 DTC but got to the point where it tells you to swap out the TAC module with a known good one TWO different times.. like basically going thru the chart and doing EVERY step after i tried going thru it the way it's intended (for example it'll say if you've got continuity on pin 26 of PCM connector B then go to step 37 and if you don't go to step 8)..i followed the chart the way it said to begin with then just went thru every number and everything checked out good as far as the wiring it had me test with multimeter! anyway, i got a TAC module off eBay and it still throws the U0107 code (I've gone back thru the tests with the new module) and I don't have a clue what 2 try next!? ANYONE'S help would be IMMENSELY appreciated!!
oh yeah btw my car has an aftermarket alarm system installed and whoever put it in did a hack job with the wiring but it's been like that since i got it in 2011. i did notice that there's a green wire coming from the alarm module that just looks chopped off and i can't find another green wire anywhere that could connect to it but I'm thinking it's prob always been that way bc in the instructions for the alarm it shows the green wire being an optional accessory so it must not have been needed and they just snipped it?
Old Sep 30, 2019 | 12:56 PM
sparc's Avatar
have you ruled out the car battery?
seems like the few threads about this indicate that is a top cause.
