Help...possible power steering failure
Old Feb 15, 2010 | 08:48 AM
durandle's Avatar
Recently my 2004 TL has been making a high pitch noise when I start up the car. It changes pitch as I rev up the engine. The noise sounds like it is coming from the power steering pump. About a month ago I replaced the o-ring on the power steering pump but the noise has not gone away. Any suggestions what it could be?
Old Feb 15, 2010 | 05:01 PM
Majofo's Avatar
Is there sufficient psf in the res?
also high pitch or whine / moan? A high pitch noise is more likely belt related.
Old Feb 17, 2010 | 10:04 AM
durandle's Avatar
It is a high pitch whine. If it is the belt do you know how much it would cost to repair/replace?
Old Feb 17, 2010 | 10:09 AM
nisreo's Avatar
Ive noticed acura ps pumps are very delicate. Ive had a few people come in with no Ps fluid (due to a leak or something) and they had drivin it only a short distance and they needed a new pump. Everything still works fine, just really loud.
Old Feb 17, 2010 | 12:08 PM
subinf's Avatar
One on the right for me
I have the same problem. Does yours go away after about 5 min and only happen in the morning? I've stopped caring as nothing seems to be affected.
Old Feb 17, 2010 | 02:26 PM
durandle's Avatar
Yes, usually after the car warms up the noise goes away. I want to get it fixed but I just wanted to get some information first so I can call him out if my mechanic says it will cost $1,000 to fix.
Old Feb 17, 2010 | 05:36 PM
Majofo's Avatar
definitely ps pump..
Old Feb 17, 2010 | 05:52 PM
Micha's Avatar
There is a TSB for this problem.
The rubber O ring on the high pressure lines deteriorates after time allowing air to pass by. Open up the top of your power steering resevoir and see if there are bubbles when someone else turns the wheel.
Just do a search for TSB and power steering.
Here is the TSB from Acura.
http://www.in.honda.com/Rjanisis/pubs/SB/b07-060.pdf
Old Feb 17, 2010 | 06:10 PM
subinf's Avatar
^ - He already replaced the o-ring.
Old Feb 17, 2010 | 11:10 PM
Micha's Avatar
Whoops. Sorry. I was in a hurry at work.
The whole hose could be bad possibly?
Old Feb 18, 2010 | 12:41 AM
Majofo's Avatar
Old Feb 18, 2010 | 12:45 AM
subinf's Avatar
Shit probably needs to be replaced. Noise has been going on with my car for quite some time and I haven't noticed any change in driveability. Until it stops working I can live with the noise in the morning.
Old Feb 18, 2010 | 07:32 AM
durandle's Avatar
Anyone know about what I can expexct to pay to replace the PS pump?
Old Feb 18, 2010 | 09:42 AM
Majofo's Avatar
roughly $600 depending on the shop with part markup.. buy the pump & diy or call some shops around, tell them you have the pump & just need an R&R.
Old Mar 12, 2010 | 12:02 PM
durandle's Avatar
FYI - I took it to my mechanic and he said it was the PS Tensioner. The part costed $60 but labor was $300. Well worth it to no longer hear the annoying whine!! Thanks everyone for your help with this!
Pham Alvan
Mar 16, 2016 09:17 AM
Euro4gen
Dec 12, 2015 03:14 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
TL14
Sep 24, 2015 04:37 PM
