Help Please
Help Please
alright i got a little problem
i get a weird noise when i turn my wheel like almost all the way on turns i get this weird noise in my front wheels but the thing is when i am on neutral gear there is no noise only when i am in gear
i got 07 tls manual help and going to the dealer part i know that my self i want to get this fixed my self
o my bad i wanted to say coming from somewhere by the wheels
when i am on neutral gear there is no noise only in gear
so if it is the pump should i replace it asap
If it was the power steering pump ou would hear it all the time, being in gear or not would not matter. It sounds like it is in the drive train, ie. trans, dif. Is it louder at slower or faster speeds, is it louder on the right or left side of the car?
then i hear whinning well when i got little faster it gets louder
It sounds like the differential, the higher the torque the more strain on the differential, casing the noise. If it is still under warenty I would take it to the dealership to have it looked at.
well and if i am not under warranty how much would it cost me to fix it any idea?
It depends on what exactly is causing the noise, and your repair ability. If it is a gear inside your diff, and you can replace just that gear, and you have the tools and ability to do the job, your cost will only be for the gear. Or you might have to buy an entire diff which can get expensive. But don't just buy a diff for the car with out definitively identifing the problem. You might want to take it to a shop to have it looked at.
If the noise is happeneing only when you turn then it might be the struts or the ball bearing.
Take you car to an empty parking lot or field and then turn right and go in circles, if the noise is there then its your left strut, else its the other one.
on any hard turn like when i turn on a light
Well then maybe the strut bars on both sides are toast. Go under the car, behind the wheels, you will see a rubber spring like object, do you see any cuts in them?
practicing nihilist
check your lower control arm bushings while your under there. Mine a couple others are shot at around 40K miles. Don't have problems like you are talking about but I encourage everyone still under warranty to check these out. It may be a trend.
Definitely not clicking? If it's clicking when you turn it's your CV's. Only time the power steering pump should whine is when your stopped/idling and you full lock the wheel. And the recall was only for a possible fire hazard - pumps still worked OK.
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
Problems come, problems go. Can't control it. I had my fair share withmy TL but with the advice I got here, I was able to get it fixed and bam! All is good
