Help! No A/C....
4th Gear
Help! No A/C....
A few months ago my 2004 acura tl a/c stopped working. Nothing but hot air comes out. I did the climate control self diagnosis and code "Q" showed up. It means there's an open or short in the passenger side mode control motor circuit. The next day I tried to do the self diagnosis again and no codes showed up but there is still no a/c. Does anyone know how to fix this problem.
I don't mind not having any a/c it just sucks when it's raining outside and the windows gotta be up in this 90 degree weather.
Ashley_UA6 (07-24-2014)
turn car on, turn a/c on
does clutch engage? if not check r134a levels. not uncommon to take a rock in the condenser and then it all leaks out. I just repaired my CL-S for the same thing last year
Does the AC clutch engage?
Do both fans turn on?
Either way you still need to hook it up to a AC machine to see the problem.
There is nothing you can do at home unless its a AC clutch relay,etc....
