help no 3rd 4th on 6mt
Old Feb 5, 2020 | 05:46 AM
sbkiid's Avatar
4th Gear
I have a 2006 6mt and for some reason I can’t figure out the issue of why I can’t get into third and 4th gear all other gears fine. I did some research and apparently these cars have a 3rd 4th clutch pressure switch or something of the sort can someone possibly help me in specifically figuring out my issue
Old Feb 5, 2020 | 07:06 AM
Refer to the attachment. Others will recommend you try ACDelco 10-4014 Friction Modified Synchromesh Manual Transmission Fluid.
Old Feb 5, 2020 | 07:09 AM
rockstar143's Avatar
pressure switches are on the automatics!
Old Feb 5, 2020 | 08:39 AM
Jackass's Avatar
Do they grind? Does the shifter move into the gates but not into the gears? Is the shifter unable to even move into the gates?
Old Feb 5, 2020 | 09:01 AM
yeah is the symptom with car on AND off?
Old Feb 5, 2020 | 11:22 AM
Old Feb 5, 2020 | 05:30 PM
sbkiid's Avatar
4th Gear
Thanks that’s what I thought
Old Feb 5, 2020 | 05:31 PM
sbkiid's Avatar
4th Gear
Only on
Old Feb 5, 2020 | 05:32 PM
sbkiid's Avatar
4th Gear
Thanks everyone I’ve just decided to get a new transmission based on the response
horseshoez's Avatar
Latent car nut
Only on
Sounds like your clutch is failing.
Old Feb 5, 2020 | 07:28 PM
That's what I was getting at...
MAYBE the syncros given that it's only 3rd and 4th...I think there was a TSB on it but I would TRYYYYY the GM Syncromesh fluid ASAP and see what's what...
I've read where it cured the 3rd gear pop.
My only reasoning for maybe not clutch is why only those 2 gears.
Old Feb 5, 2020 | 07:49 PM
ehh a new tranny is an easier solution
Old Feb 6, 2020 | 08:01 AM
lol, a new tranny is like $3-4k....if you can even find it new...
perhaps it's just a bad clutch?
