Help me. TL-S blows fuse when put in reverse
Old Sep 10, 2014 | 10:07 AM
Type-S_Guy's Avatar
3rd Gear
I own a 2007 Acura TL-S 6 MT. At first I was having a problem with the starter, then on one start up my gauges, windshield wipers, windows, and back-up camera wouldn't work. I found out it was a blown fuse. I replaced it and everything started working again, until i went into reverse and nothing worked. I checked the fuse and it was blown. Any ideas what it could be?
Old Sep 17, 2014 | 01:12 PM
I hate cars's Avatar
Have you had a clutch put in recently or the transmission removed for any reason? One member had that problem years ago except it would kill the engine in reverse. It turned out to be a pinched wire or a bad switch, can't remember which.
Old Sep 17, 2014 | 04:19 PM
ONTHEMOVE's Avatar
I need S lips!!
Check your inline for your backup camera, also make sure you all the correct bulbs in the correct spots, change any bulbs recently?
Old Mar 12, 2015 | 01:00 PM
TLin05's Avatar
Just wrote the below as a PM, then learned Type S Guy's message box is full Posting here in case he's monitoring or anyone else can assist -- thanks!
Did you ever figure this out? By now I'm sure you did, or you no longer have the car... Am asking because I have the exact same problem with my 05 TL 6-MT now.
Refer to the posts by "LaCostaRacer" on this forum in July-August 2014. I had symptoms of the chafed wiring-harness problem with my back-up lights over the past couple months, I'm almost certain there is a relationship. Both lights had stopped working shortly before the first fuse blew.
I'm getting this fixed soon (avoiding reverse and carrying extra fuses til then!) and am curious if you can confirm the problem or maybe point me in another direction.
Old Mar 19, 2015 | 08:55 PM
TLin05's Avatar
Update -- yes, that was it. All fixed
Old Apr 24, 2015 | 10:12 AM
Nastynorth's Avatar
3rd Gear
Fuse keeps blowing
My meter fuse keeps going out, that would kill all the windows, signals, AC, reverse light. What was the fix?
Old Apr 24, 2015 | 10:15 AM
Nastynorth's Avatar
3rd Gear
Can you tell me what you had to replace, fix?
Old Feb 6, 2025 | 10:20 AM
Webb's Avatar
4th Gear
I'm having the same issue with my tsx has anyone found out what it could be?
Old Feb 6, 2025 | 10:22 AM
Webb's Avatar
4th Gear
I would love to know myself, my 2006 Acura tsx is doing the same thing
Old Feb 6, 2025 | 10:30 AM
Did you happen to put in some LED bulbs in the reverse socket at some point in the past @Webb
Old Feb 7, 2025 | 02:10 PM
Webb's Avatar
4th Gear
I didn't change any bulbs, Im having the same problem with my signal, AC , windows and wipers. When I put the car in reverse it blows a 7.5 fuse. I've disconnected the reverse lights and it still blows a fuse. I have looked on YouTube about a reverse light switch but I think it's different with a automatic because it's not on my car like the video and it's the exact car. If I knew what helped the guy in thread above would be awesome
rockyboy
Aug 4, 2024 10:35 AM
Acura9915
Feb 24, 2020 01:27 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
drewdeezy03
Sep 3, 2015 08:04 PM
