help major problemssss!!!!!!
Old Oct 31, 2010 | 09:13 PM
Resse4x's Avatar
05 6speed
ok the problem i have is the worst brought it to the dealer they dont know wat to do. when i drive and im coastin and go to accelarate it jerks a lil bit then i was on the highway and the vsa light came on and i could not accerlarate at all had to turn the car off then it was okay any ideas on wat it is
Old Nov 2, 2010 | 10:07 PM
nasty_nos's Avatar
Maybe a fuel filter issue or even injectors? I am not sure and just throwing an idea out there. Hopefully it is something simple and get it repaired!
Old Nov 2, 2010 | 10:13 PM
did you ever check into the APP sensor???????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ????????????????
the threads that I pointed you tooo, had the same symptoms as you. hesitation and the VSA indicator going off. I would check into the APP sensor like I and others have suggested to you.
you started 50billion threads on the same subject.
It wont help you diagnose your problem.
the best way to diagnose, is to search through our large database of threads....when you find something closely related to your problem.....continue to read. you'll read a fix for it. Unless you dont have basic reading comprehension skills, then you're a lost cause. I'm just writing for the fuck of it because I dont really think you're going to read this shit. Because you did not read the other threads on where I HELPED YOU find and diagnose the problem. I dug up threads on hesitation and not passing a certain RPM, like you had previously stated in your OTHER 50billion threads. Read those. you will learn lots. I promise. if you continue to post threads about the same subject over and over again, no one will help you....like the boy who cried wolf....do you want to be eaten by a wolf?
Old Nov 4, 2010 | 08:24 PM
SilverJ's Avatar
I had the same problem, after going to the dealer multiple times and having them do a "reset" of the ECU (waste of time), they finally conceded that the issue was what I said it was from day one(with knowledge I obtained from this board)--the APP sensor.
c1souk
Sep 28, 2015 11:20 AM
mars
Sep 28, 2015 11:03 AM
hpfiend
Sep 27, 2015 06:59 AM
Hines57
Sep 24, 2015 01:58 PM
