Help - how to remove the stopper screw on the door panel?
Old Jun 8, 2009 | 08:50 AM
Charles12's Avatar
My 2008 TL has rattle from day one I got it. One of the annoying one comes from the passenger door. The dealer is not willing to do anything.
I tried to open the door panel and had a difficult time to remove the stopper screw (on the lower -door open side, which is convered with a rubber cover).
Any one has any experince?
Charles
Old Jun 8, 2009 | 09:30 AM
dablackac's Avatar
You can't suppress the rattles, only play your music louder. You'll go crazy trying to find their sources!
Old Jun 8, 2009 | 09:35 AM
Trew's Avatar
To answer your question...
From the side of the rubber stop, take a slotted screwdriver and place it between the metal part of the stop and the door and pry up slightly as you use a phillips screwdriver to turn the screw.
The pressure you put against the stop will stop it from turning with the screw.
I've taken my door panel off at least 5 times and this trick works like a charm every time.
Old Jun 8, 2009 | 10:49 AM
Charles12's Avatar
Thanks Trew.
I want to replace the whole stopper, including the philips screw, the part stick into the door (how to get this part out out the door- just pull hard?). I just try to open the door partially from below. I had no idea and am not confident to open the entire door. Maybe you can give some detailed description on how to open the door step by step. I am afried of breaking parts? Like the stopper I tried to but some demage I have to replace it.
Old Jun 8, 2009 | 01:10 PM
LoveMyTL-S's Avatar
Perhaps these will help:
https://acurazine.com/forums/3g-tl-2004-2008-93/front-rear-door-panel-handles-wstrip-glass-window-regulator-removal-3g-garage-f-016-a-603296/
https://acurazine.com/forums/3g-tl-2004-2008-93/how-remove-door-panels-3g-garage-f-016-a-559144/
3G garage is your friend.
Old Jun 8, 2009 | 05:29 PM
Adobeman's Avatar
The DVD-A Script Guy
Those things suck. I wrestled with one for an hour. I'm convinced the dealer tech over tightened it after doing a window regulator under warranty.
Once it's out and you do replace the insert (part in the door) DO NOT tighten the stopper any more than just snug or else you will risk "spinning" the insert and rounding off it's corners. If you round them then you are in trouble all over again.
Old Jun 9, 2009 | 09:05 AM
LoveMyTL-S's Avatar
Actually, I just left mine off after stripping it and then getting it out. You have to be really gentle with that screw. Don't force it.
Old Jun 9, 2009 | 12:04 PM
jweb12's Avatar
I'm waiting for my replacement insert/stud from acuraoemparts. After taking that panel off several times I've had to resort to wedging a putty knife in there to keep the base from turning. I need to pull the panel again so figured I'd replace that piece.
Old Jun 10, 2009 | 10:46 AM
dwb993's Avatar
What is the part number for this and is it different for left/right?
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old Jun 10, 2009 | 12:06 PM
jweb12's Avatar
Part 16 in the diagram. Part #72144-SZ3-013. At least, that's what I ordered. Should be here in a couple days. If it's not the right part, I'll let you know.
Old Jun 11, 2009 | 12:12 AM
NE14RoxCJ's Avatar
Just stick some glue on it and be careful when you screw it in. That insert may be difficult to get out and replace. We use threaded insets at work that require a "puller". Like a pop rivet gun, it just pulls the insert up by the threads and it expands on the other side of the door skin pulling it tight. If its not pulled tight enough, it'll spin when you put a screw in it. I dripped some epoxy around mine on my driver door. I've had my panel off a couple of times since then (Moleskin ordeal). Just have to be careful putting the screw in. Maybe I'm wrong and it's not that type of insert. I hope. Let us know.
Old Jun 11, 2009 | 07:57 PM
jweb12's Avatar
Got the part. The number I posted above is correct. Just need to get some time to pull the panel (yet another moleskin problem) and make the switch.
Old Jun 12, 2009 | 08:10 AM
dwb993's Avatar
Thanks, bud. I appreciate it.
Old Jun 12, 2009 | 09:24 AM
LoveMyTL-S's Avatar
If you don't mind, where did you order it from and how much?
Old Jun 12, 2009 | 10:23 AM
dwb993's Avatar
There's a link in my post #9 above.
Old Jun 12, 2009 | 10:43 AM
LoveMyTL-S's Avatar
On the website it looked like this was the correct part#:
72142-SM4-000 STOPPER, DOOR
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
govtcheez
Oct 1, 2015 12:21 AM
CadiGTi
Sep 14, 2015 06:37 PM
