help !! engine mounts ?
Old Jul 10, 2009 | 11:59 PM
djonyx88's Avatar
onyX.
i took the car to the shop, and found out that all my engine mounts where all blown they told me that there is a total of 5 mounts including transmission mounts just checked that the price for oem components for all mounts is VERY expensive is there any way i can get aftermarket ones ? i went into excelerate page and they have em' but they are only 3 for 290.. what about the other 2 ??? thanks
csmeance's Avatar
3 of them are for the motor, I doubt that your transmission mounts are done as well... the ones from excelerate are a bit firmer and stronger than the OEM ones.
Old Jul 11, 2009 | 12:03 AM
djonyx88's Avatar
onyX.
yea they are.. just saw them while mec was revving eng n they where blahh going everywhere. i would have to get those oem right ?
Old Jul 11, 2009 | 12:32 AM
TL on "20"'s Avatar
when i start my car in the morning it vibrates it can be the mounts???
Old Jul 11, 2009 | 12:05 PM
Copperbottoms's Avatar
OP, how many miles do you have?
Old Jul 11, 2009 | 04:11 PM
TeknoKing's Avatar
If you don't mind a slight cabin vibration but with improved handling, no wheel spin or hop, and lifetime warranty on solid motor mounts, go with innovative mounts. I love them.
Old Jul 11, 2009 | 09:22 PM
csmeance's Avatar
it'll vibrate a bit since the car rev's a little higher and misfires slightly to warm up the cat's due to ULEV systems. A good way to know if they are broken are to have the car completely warmed up and go into the middle of the road. Stop like you would at a red-light. Does the shifter, steering-wheel or seat vibrate? If yes, shift into neutral, does it stop? If yes, then your mounts are bad.
Old Jul 11, 2009 | 09:23 PM
csmeance's Avatar
You do realize that the bolts could be loose as well for the mounts right?
Old Jul 12, 2009 | 06:38 PM
TL on "20"'s Avatar
Ohh ok in was geting woried in will mace the test yo make sure
Old Jul 13, 2009 | 03:02 PM
05TLRIDER's Avatar
My car does that almost exactly as you described it, but it's only been since I put the XLR8 j-pipe on......I've checked connections, but they are tight. How can I tell if the mounts are bad? Is it something I can visually see?
Old Jul 15, 2009 | 01:49 PM
Majofo's Avatar
^ you can see the front & side mount clearly.. it's difficult to tell if they're bad. You need one person to watch the front mount to check the clearance to tell if it's bad.. the side mount you can remove by jacking up the engine with a wood block under the oil pan.. if it's ripped & leaking.. it's a goner and a good indication that the front mount has failed as well.
Old Sep 20, 2009 | 10:14 PM
rolan04tl's Avatar
So I went to my dealer (Bella International in Purtor Rico) for sevice to my car and, amongst a bunch of other things, they said I had to change the front motor mount, two transmission mounts, and two crossmember mounts. I have never trusted this dealer, and now that I realized they also said I had to change my front brake pads and, when I did, I discovered they werent even down to half worn, I trust then even less. I really have no clue if I should really check if these mounts are done or I could live with this. I have no issues with the car when I drive it. Any advice?
Rolan
Old Sep 20, 2009 | 11:16 PM
csmeance's Avatar
Rolan
go to an independent shop and see what they have to say.
Old Sep 20, 2009 | 11:19 PM
tenzingsherpa's Avatar
J36Twingt28r's,nextgt30r
Yeah dude innovative mounts for the win!!! Lifetime warranty, along with performance benefits!!!!
Old Jul 26, 2010 | 05:26 PM
inordiNate's Avatar
Dealership is hosing me on my 100k service
First I call in and they say $600 then when I show up its $759 timing belt service, Mr. Brown - at least they're polite. I ask what happened to the $600 and they said, "Oh, we must have quoted you on a 92 tsx." That's weird, I didn't think they made the tsx in 92, but I'm like whatever. I just want to get it done and move on, don't really have time to be focusing on this. About an hour later I get a call from the service department and the timing belt tensioner is shot, my engine motor mounts are blown and my breaks barely stopped the car when they pulled it into the service bay. They make it sound like total pandemonium has broken out in the service department and a couple of the technicians are in the corner crying from what they just saw. But in a calm voice the service lady says. The good news is that we can fix one of the motor mounts for only parts $95. The front motor mount is going to be $410 and we'll throw in the tensioner for just part too at $150. And we can get the brakes all back together for you for just $500, this way when we pull the car back around from the service department it wont careen out of control into the show room floor.
What's the deal? Am I getting hosed or what?
I told them to replace the tensioner as i had a bad timing belt experiance with a toyota camry I tried to replace in 00.
Am I biting off more than I can chew with the motor mounts?
Old Sep 9, 2010 | 09:02 PM
hrod26's Avatar
I am a relatively new DIY'er and replaced all 3 motor mounts. You will probably need to get some extensions for your socket set as the front and rear (especially) are a PTA to get to. Otherwise floor jack, jack stands, basic tools you should be fine. I would def give yourself a weekend to get it done.
Old Sep 10, 2010 | 07:12 AM
Turbonut's Avatar
Sorry, but a SLIGHT cabin vibration is an understatement.
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
Mr.Tea
Sep 14, 2015 09:58 PM
