Help-engine leak
check the plug first, but otherwise, yes to the grommet/s. If you have the valve covers off to replace the grommet/s, might as well replace the valve cover gasket/s. And as long as your there, check your valve clearance if you feel up to it.
One note: be very careful when torqueing the valve cover bolts. The spec is only 8.7 ft-lbs. The bolts have stops on them, if you hit the stop before reaching 8.7, stop. If you don't have a torque wrench that reads that low, I would only use a 1/4" ratchet to avoid over-torqueing.
rockstar143
Apr 24, 2020 06:59 AM
hondeducation
Feb 26, 2016 09:16 PM
kevinf41
Jan 26, 2016 10:10 AM
rapid3642
Dec 16, 2015 03:29 PM
