Help Electrical Issue
Old Mar 17, 2015 | 03:23 PM
sjc's Avatar
sjc
5th Gear
Took my car to auto radio place, the guy removed my HF unit & replaced and plugged the sunroof plug to the light cluster, my sun roof went up, dash lights, turn signals, all windows, are dead. Interior lights are fine, not one blown fuse under dash or hood. Can it be a modual. Door lock/ alarm is fine, open doors and blue dash lights and driver 1 detected works. Turn on headlamps NO DASH LIGHTS. Took off battery, thought might reset, no way. Can I crank roof down. ALSO A/C not working. The guy has no clue, I withheld pmt. & won't let him touch the car. Most auto electric want $99hr to diagnose. Dealer $139.00 hr. ANY SUGGESTIONS?
Old Mar 17, 2015 | 03:38 PM
polobunny's Avatar
Registered Bunny
I don't believe the not one blown fuse. Either fuse 21 (most likely) or 7 (less likely) is dead under dash. Interior lights, for the record, are on fuse 6.
Let's troubleshoot that, then the AC.
Old Mar 17, 2015 | 10:47 PM
sjc's Avatar
sjc
5th Gear
Going To Check Again!
Thanks for reply, going to check again. I went to Auto Zone, they pulled fuses said none under dash or hood are blown. Had back surgery last month but going to get under there Wed. I held manual & called out fuse numbers to the employee. I noticed the power windows each have a fuse under dash & 50 amp screwed in under hood box. I'm going to look at every fuse, if they are in fact good, what next? Relays? Dealer said could be ECM modual? Quoted possibly $500. just to trouble shoot. Dealer who has big reputation for rip off tells me might have to remove dash to get to module. Also can't tell if check engine light is on. Should I try to see if a code comes up? So frustrated & upset, waited a year to replace H/F unit. At least the guy admits to plugging in the wrong plug, just can't see how Home Links & interior lights work & dim. Is there a manual crank for sunroof like Audi? Sorry for the ramble.
Old Mar 18, 2015 | 08:27 AM
polobunny's Avatar
Registered Bunny
I'd start by checking the mentioned fuses. Then we can work from that. No use preparing for apocalypse if all you need is a fuse replacement.
Old Mar 18, 2015 | 12:25 PM
sjc's Avatar
sjc
5th Gear
I owe you dinner polobunny
Fuse number 21 was blown! Now have windows, turn signals, washer/wiper, dash lights and the HF board I baked in the oven paired my Samsung Galaxy. You are the best, ever in Tampa, look me up (954) 917-6750. Thanks, Stuart
Old Mar 18, 2015 | 12:30 PM
polobunny's Avatar
Registered Bunny
Originally Posted by sjc
Fuse number 21 was blown! Now have windows, turn signals, washer/wiper, dash lights and the HF board I baked in the oven paired my Samsung Galaxy. You are the best, ever in Tampa, look me up ZIP-ZIP-ZIPP. Thanks, Stuart
Hey Stuart, glad you got it fixed. Montreal's a bit far from Tampa, so I likely won't be taking on your offer anytime soon but I appreciate the kind feelings. I've also edited the number from my quote so you don't get picked by phone spammers or anything.
Is there anything else that doesn't seem to be working now?
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
brandnewcolony
Sep 12, 2015 10:39 AM
Aug 30, 2015 02:39 PM
