Help ! Can't get hub and knuckle off the drive shaft !
The first item I do after the nut is loosened is to make certain the axle spline is loose inside the hub. Leave the nut at the axle end and hit the nut to drive the axle back, but with everything unbolted, there will be no resistance to hold the hub steady and drive the axle back, so take the entire assembly out of the car then you'll be able to support the hub and drive the axle out.
Just an FYI, that's the passenger side so the axle doesn't get remove from the trans, but from the bearing support.
marcelft
Jul 10, 2018 06:17 PM
justin7779
Dec 25, 2015 10:33 PM
jmoney2001
Sep 11, 2015 12:07 PM
