Help
Old Apr 20, 2017 | 09:41 PM
BcEkit's Avatar
3rd Gear
Help
I accidentally put in 15fl oz of oil treatment in my 2008 Acura TL thinking it was fuel injector cleaning. What do I do? Is there an easy way to flush the tank?
Old Apr 20, 2017 | 10:28 PM
Ron A's Avatar
Administrator
Welcome to the forums.
Since this is a technical issue and not a "New Member Introduction" I moved this thread to the appropriate subsection so you can hopefully get more help.
Old Apr 20, 2017 | 11:46 PM
nfnsquared's Avatar
Depends on the formulation. You might be fine. What exactly did you put in the tank? Call the manufacturer and ask them. Read post #9 of this thread:
Accidentally poured zMax engine treatment into fuel tank. Did I wreck my car?
Old Apr 21, 2017 | 01:18 AM
BcEkit's Avatar
3rd Gear
I put STP oil treatment + stop leak for high mileage
Old Apr 21, 2017 | 10:50 AM
If i were you, I'd get a siphon and start draining all that gas...
Old Apr 21, 2017 | 11:28 AM
nfnsquared's Avatar
OP, you basically put 15 oz of mineral oil in your tank:
http://www.stp.com/sites/default/fil...2015-06%29.pdf
15oz in 17 gallons is 0.6%. Mineral oil is used in some fuel stabilizers. You might be fine, but I can't say for sure. I'd make sure the tank is full and see if you throw any codes or notice performance issues.
Keep us updated.
Old Apr 21, 2017 | 12:44 PM
Keep us updated.
awesome that you researched this!
i was kinda curious after you had pointed out the zmax was just a darker dye
Old Apr 22, 2017 | 11:07 AM
nfnsquared's Avatar
OP, any updates?
And make sure you're using Top Tier gas for at least (hopefully always) the next few tanks...
Old Apr 22, 2017 | 01:49 PM
truonghthe's Avatar
there is a drain bolt on the gas tank and if you can't locate the bolt then get some kind of pump and pump the fuel back out via filler neck.
Old Apr 24, 2017 | 02:55 PM
BcEkit's Avatar
3rd Gear
yeah it works great! Thanks for the help! I definitely siphoned the gas immediately. I've driven it with 2 or 3 tanks since then and hasn't had any problems. Crossing my fingers though!
