Help!! 3G TL end link
Old Nov 23, 2011 | 12:31 PM
Ronin_TL's Avatar
9th Gear
Unhappy Help!! 3G TL end link
Hi, I was trying to take off the rear endlink without an allen wrench and spun the shaft with the nut still on it. Is it ok? If not, can I fix it or do i have to get a new one? is it a ball joint inside the endlink? And also, will it throw off the geometry or anything? Any info is appreciated.
Old Nov 23, 2011 | 12:35 PM
so...you still havent taken off the nut?
if so, its fine. its supposed to spin. thats why its required to have an allen key.
Old Nov 23, 2011 | 01:12 PM
jokerman826's Avatar
Jokerman
just hope it isnt rusted out, i did mine and the allen key hole just stripped out, so i bought new ones and will cut off the old.
Old Nov 23, 2011 | 04:38 PM
Ronin_TL's Avatar
9th Gear
Well, it's a socal car so the rust isn't too bad. Yes, I took the nut off eventually but at first, the post just spun with the nut on it a few turns.
Old Nov 23, 2011 | 04:43 PM
Bearcat94's Avatar
AZ Community Team
Don't need two threads. You have replies in your other thread.
Here: https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/help-rear-end-link-question-839605/
In case you lost it.
eastcoastguy
Oct 29, 2015 03:00 PM
lanechanger
Oct 13, 2015 10:56 AM
Rcelestino93
Sep 23, 2015 10:01 PM
Brandle34
Sep 23, 2015 07:20 PM
