Help with 2 problems
Old Sep 21, 2009 | 05:41 PM
gungrave's Avatar
First problem is that key memory won't work for seat positioning. Second when i put it on reverse the left side mirror won't go down. The battery has been replaced by the dealer two months ago, could that be the problem? Thanks for any suggestions.
Old Sep 21, 2009 | 06:22 PM
Will Y.'s Avatar
Registered but harmless
It sounds like the remotes were unlinked from the car-- just re-link.
Check the mirror switch-- it should be on the left position for the left mirror to drop down, on the right for the right mirror to tilt down and in the middle for no tilt.
Old Sep 22, 2009 | 02:40 AM
gungrave's Avatar
How do you re-link the remotes? And i have the switch on the left position but it still doesn't go down, do you think it could be a bad fuse or something like that because it doesn't work on any position(left or right mirrors both don't work)
Old Sep 22, 2009 | 09:13 AM
LoveMyTL-S's Avatar
It's simply amazing what you can find the 3G garage:
https://acurazine.com/forums/3g-tl-2004-2008-93/programming-remote-transmitter-keyfob-3g-garage-l-079-a-556315/
Old Sep 24, 2009 | 10:35 AM
gungrave's Avatar
Ok i got the remotes and the mirrors working. I re-linked the remotes and changed one blown fuse and the mirrors starting working again. Thanks acurazine.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
