Heeeellllppppp!!!!!!
Old Jul 12, 2017 | 05:25 PM
Hmooblauj's Avatar
6th Gear
So I just purchase a 2004 Acura TL 6speed with bad brakes. It drove fine before I did a brake job. (As she said) But I've done plenty of brake jobs before and this is one job I couldn't figure out. Ive changed all four brakes due to bad pads. After replacing all four, I bled them from all four wheels. Afterwards, i test drove the vehicle. It drove fine for approximately 5 miles. When I realize my car was hesitating, the vsa light came on and I smell a burning odor. I pulled over and put it in first. Then car wouldn't move. I tried to push. Nothing. So I towed it home and jacked up the vehicle. I spin each wheel and they spin, but rough. So i decided to change my master cylinder. Changing it, the vehicle still giving me all these problems.
Could it be a defective master cylinder?
​​​​​​I'm out of ideas. Please help!!!
Old Jul 12, 2017 | 06:09 PM
peter6's Avatar
Well... Do you know how to do brake jobs?
Do 4 brakes? Meaning 4 pads and rotors, or 4 calipers?
Why you bled them? You cleaned calipers / hardware? You put some grease? Slide pins are greased and moving freely? Can you collapse pistons?
Old Jul 12, 2017 | 06:24 PM
guitarplayer16's Avatar
You need to get the code checked at a shop. When the VSA light comes on it can indicate a problem with a sensor, and you can get the code checked out.
Old Jul 12, 2017 | 10:02 PM
Hmooblauj's Avatar
6th Gear
I replaced the pads on all four. No rotors needed. They're still smooth. I also did all that yes.
Old Jul 12, 2017 | 10:03 PM
Hmooblauj's Avatar
6th Gear
I'm located in California. Can any shop be able to read the vsa?
Old Jul 12, 2017 | 10:37 PM
Majofo's Avatar
Check your ABS sensors.. probably damaged one.. domino effect ----> VSA code (get it read anyways), chump mode
Old Jul 13, 2017 | 06:42 AM
08KBP_VA's Avatar
Not your master cylinder. Different behavior if it was.
Why would you bleed brakes after pad change? Was there another issue?
Anyway, did you pull all wheels and check all 4 bleeder screws and look for a leaks?
Any shop with the right code reader can read codes, yes.
Old Jul 13, 2017 | 07:37 AM
Jackass's Avatar
Keep in mind...this is a 6MT...so Brembo up front. Did you bleed those correctly?
My guess is you had a pad dragging, it got hot and clamped down tight. I am assuming the burning smell was hot brakes. So either stuck caliper, or mis-aligned pads are my thoughts.
Old Jul 13, 2017 | 08:11 AM
jzhu625's Avatar
get the car scanned first.
Old Jul 13, 2017 | 04:39 PM
Turbonut's Avatar
Did the pistons move in easily when doing the job? Nee to check which corner is hanging up. If a brake locks up (Hot), try and move the pads away from the rotor, but if they don't move, open bleeder and try again. If the pads are able to move, replace brake hose.
