heater blows cold air
Old Jan 2, 2018 | 01:34 PM
Dello514's Avatar
3rd Gear
my acura tl 2006 the heater blows cold air when i start the car i wait like 5-7 min after i drive but when the car is stopped there's cold air but when i drive it then it start to blow hot air.... i changed my thermostat and i still have the problem
Old Jan 2, 2018 | 04:17 PM
Chojun's Avatar
Welcome - this is the 2G forum - you need to post this in the 3G forum.
Old Jan 2, 2018 | 04:40 PM
Ron A's Avatar
Administrator
Welcome to the forums.
This thread has been moved to the model specific forum for better response.
Old Jan 2, 2018 | 05:16 PM
horseshoez's Avatar
Latent car nut
Sounds like your car may be low on coolant.
Old Jan 2, 2018 | 10:21 PM
Dello514's Avatar
3rd Gear
My coolant is good i even changed the thermostat
Old Jan 2, 2018 | 11:44 PM
stevemk07's Avatar
Burp the coolany system.... Take the cap off... Top off with the right coolant... Start engine.... Turn temp to high, fan speed low, let fans come on twice.... Shut off engine... Top up if necessary....
Leave cap on loosely with rags around cap to absorb overflow....
Ifthisdoesnt work you may need other reapairs... Themostat stuck open perhaps.... (New thermostat needed)
Old Jan 3, 2018 | 08:32 AM
Jackass's Avatar
- Burp coolant
- Check the HCV (Heater Control Valve) for movement and leaks
Old Jan 3, 2018 | 07:20 PM
Dello514's Avatar
3rd Gear
I changed the thermostat already and i filled with new coolant for Acura already what do you mean by burp the coolant system
Old Jan 3, 2018 | 09:46 PM
stevemk07's Avatar
You quoted how to do it
Old Jan 4, 2018 | 12:40 PM
Nytetime6's Avatar
Its the heater control valve. I had the same problem. Car would blow heat while moving and if I was stopped at a stop sign or at a red light then it would blow cold air. One day the heater control valve broke spilling coolant everywhere. I had it towed to the dealer and they said it was the heater control valve that broke. They replaced that and now the heater works like it should.
AColli3r
Jul 24, 2025 09:45 AM
Jul 16, 2017 07:33 AM
jpelizza
Jan 10, 2017 06:03 AM
Onyxthecat
Sep 3, 2016 10:58 AM
rets
Jan 1, 2013 09:50 PM
