Heater Blower Delay
Old Dec 21, 2016 | 03:25 PM
optical24's Avatar
Question Heater Blower Delay
Hello Fellow Acuraziner's,
I have been searching the forum for anyone that's having a similar issue as I am. But most threads are about their A/C/Heater blower not working. So my issue is when I turn on the heater there won't be any heat coming out of the vents. However, after 2-3 seconds I hear the blower running and heat is being dispensed through the vents. This has never happen before because the blower will turn on instantly whenever I turn on the heat. The display screen does show the temperature and the fan speed. Therefore, is this a symptom that the blower is going bad? Temperature in Canada (where I am) is hovering around -15 degrees Celsius so I want to fix this problem as soon as I can.
Thank You.
Old Dec 21, 2016 | 03:45 PM
eastcoastguy's Avatar
I am assuming it has gotten that cold before and it didnt do what your describing. I was thinking maybe slight delay because it was soo cold.
Old Dec 21, 2016 | 04:25 PM
optical24's Avatar
Thank you for replying. There's still a delay even after 20-30 minutes of driving. According to the following thread "https://acurazine.com/forums/2g-tl-problems-fixes-117/c-heater-blower-repair-diy-775458/" I might check out the blower resistor to see if there is any corrosion.
Old Dec 21, 2016 | 04:28 PM
WDPanda's Avatar
2-3 seconds doesn't sound bad to me. it does have to spin up
Old Dec 21, 2016 | 04:30 PM
Is this right when you start up the car? What's your Car temperature at when testing this?
Old Dec 21, 2016 | 04:49 PM
optical24's Avatar
But the delay has never happen before. Last year, the temperature was -35 degrees Celsius and the blower came on instantly once I turn on the heater.
Today, the temperature was around -13 degrees Celsius. I first experience this issue in the morning on a cold start and even after 20-30 minutes around town I still get a delay on the blower if I turn the heater back on.
