Heated side view mirrors button stuck?
Old Feb 18, 2010 | 09:22 PM
Project X's Avatar
Heres a picture of what I'm talking about but not my actual car. The item in question is the circular button with the mirror picture. Can someone confirm if this is suppose to be a button because in my car it seems like its pushed in and not "press-able". not sure if the previous know mistakenly pushed it and it got stuck. When I turn on the interior lights it does light on so I believe it works.
thanks for confirming.
Old Feb 18, 2010 | 09:36 PM
nfnsquared's Avatar
Yeah, it's a push button to turn on/off the mirror heat. The light (orange, the small rectangle window in the switch, not the back light) should come on when the switch is pushed in. It doesn't move very much on my car, maybe about 1/8". Compared to the button on my car, it looks like it is out. When pushed in on my car, the bottom half of the button is flush with the dash.
Old Feb 18, 2010 | 10:04 PM
Project X's Avatar
ah - looks like i need to fix mine somehow.. should i just pry off that entire piece to reset that button or would that cause more damage? if the wires have some play and not really tight then i should be able to pry it off...
Old Feb 18, 2010 | 10:13 PM
nfnsquared's Avatar
No! Remove the front panel (look in the DIYs in the Garage for scans) to get to the switch from behind the panel.
Old Feb 18, 2010 | 10:16 PM
91lgndsdn's Avatar
Or, you if you can just replace the switch. It isn't that hard to get that panel off and replace it. About $20. and a few minutes work. Good luck.
00435190-SEP-A11 SWITCH ASSY., REMOTE CONTROL MIRROR 1 2004 TL $20.57
Old Feb 18, 2010 | 10:19 PM
Project X's Avatar
thanks! can i get a link to the DIY in the garage? i only see cars in the garage area of the forums and the search on there looks like it just searches for members and their rides...
id like to try and fix it myself first.. if it doesnt succeed then ill get a new switch. thanks
Old Feb 18, 2010 | 10:27 PM
nfnsquared's Avatar
The "3G TL Garage". It's the last (6th) stick post in the main 3G forum.
91lgndsdn's Avatar
I don't know where the diy is but the panel is pretty easy to remove. there is just one plastic screw/clip under it near the center console you have to remove and then you pull it right out. it is just snapped in.
this you tube links shows a guy pulling the panel out. just don't forget to get that plastic screw/clip out first.
http://www.youtube.com/watch?v=Pf7ERvg5cNk&NR=1
I just had to remove mine last week to replace the bulb in the VSA switch. good luck
Old Feb 22, 2010 | 09:49 AM
Project X's Avatar
turns out the button wasnt stuck.. i pressed it firmly and it can out. i havent really driven the car that much since i got it but everything is fine. thanks for the info guys.
rockyboy
Aug 4, 2024 10:35 AM
Rocktman1
Oct 31, 2015 02:33 PM
sockr1
Oct 1, 2015 01:31 AM
PortlandRL
Sep 14, 2015 12:01 PM
dre707
Sep 8, 2015 08:32 PM
