couple problems..please help im a newb!
Old Feb 20, 2010 | 11:29 PM
oHsicKtL's Avatar
1. my front blinkers wont blink but they are on...
2. one side of blinker blinks really fast while the other is normal (happened after i blacked out headlights..)
3. i blacked out my headlights and now my lights are having alot of outburst to the side of headlights (not brights on ground), it barely lights up the road at nights and it can be dangerous on dark roads..
4. radio doesnt work, wont pick up a signal, i bought a new antena thinkin the old one was messed up but that is not the issue, can i get xm radio without being able to get regular radio?
thanks and sorry i searched but only found similar issues, but couldnt find a resolution..
Old Feb 21, 2010 | 04:37 AM
AckTL05's Avatar
Former Sponsor
did you spray the reflective housing behind the bulb black?>?
Old Feb 21, 2010 | 10:15 AM
Xpditor's Avatar
Can you pull it up a little closer to the computer? I can't quite see it.
Pardon the sarcasm but these self-initiated problems are difficult to diagnose remotely.
Perhaps someone here has had the same experience and may be able to offer some suggestions.
Old Feb 21, 2010 | 10:33 AM
shadowkahn's Avatar
after you played with the headlights, did you get the right bulb in the right socket?
fast-blinking blinkers generally indicate that the other bulb on that side is burned out, missing, or the wrong bulb.
The cause of your problem seems. . . obvious? Yes, surprising though it may be, blacked out headlights don't emit as much light as stock. After you recover from the shock of this newfound knowledge, go and unblack-out your headlights and your problem will be solved.
It depends on why your radio doesn't work. How did you buy a new antenna, since the TL doesn't have a normal radio antenna? Where did you put it? does anything else on the stereo work? As for your question, yes, XM and terrestrial radio use two different types of antenna.
Old Feb 21, 2010 | 11:15 AM
oHsicKtL's Avatar
the person that sold me the car said he bought a new antena.. my blinker light turns on but it doesnt blink
Old Feb 21, 2010 | 11:26 AM
oHsicKtL's Avatar
also, is there any way to keep the cooling fans on without turning the a/c on?
Old Feb 21, 2010 | 08:54 PM
Xpditor's Avatar
Why would you want to? They are thermostatically controlled. They only come on if the temp gets too hot.
Old Feb 21, 2010 | 09:46 PM
Jackass's Avatar
You can either hit auto or manually set the fan speed and then hit the A/C button twice to disengage the compressor. I do this all the time during the winter since I do not want the compressor hitting constantly when sitting in traffic. I only let the compressor run when I need to de-fog the windows.
Old Feb 22, 2010 | 09:46 AM
Xpditor's Avatar
Oh. My bad. I thought you were talking about the radiator cooling fans.
Yes. You can turn the a/c off by pushing that button. The display will confirm "AC OFF".
Old Feb 22, 2010 | 09:58 AM
oHsicKtL's Avatar
And yes everything else on my stereo work beside the radio, i have a navi
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
spudweb
May 22, 2016 02:39 PM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
hashbrown
Sep 29, 2015 12:13 PM
AcuraKidd
Sep 25, 2015 11:18 PM
