Heated mirror problem
Old Jan 18, 2011 | 03:36 PM
undertaker's Avatar
07 tl-s heated driver side mirror
Hello everybody!
I need some help with my 07 tl-s driver side mirror- the heater does not work while passenger side is heating just fine. Is this a fuse or is it a glass? Any help would be great, thanks all!
Old Jan 18, 2011 | 03:55 PM
undertaker's Avatar
I have also noticed today that rear window defroster doesn`t work. the light on the console comes on but no heat...I checked the fuse and it is good, any idea what this could be? Thanks in advance for any help!
Old Jan 21, 2011 | 08:37 AM
undertaker's Avatar
any help, anyone ?
Old Jan 21, 2011 | 11:13 AM
nfnsquared's Avatar
For the rear defog, which fuse did you check?
For the mirror heat, they're both controlled by the same fuse, so likely the left heating element is bad or you've got a bad connection on that side.
Old Jan 21, 2011 | 06:24 PM
undertaker's Avatar
I did check both fufes like manual says: rear defroster and defroster coil...they seem to be ok, today I have noticed that rear window defroster works, but heated driver mirror does not...
rockyboy
Aug 4, 2024 10:35 AM
cycdaniel
Dec 17, 2019 10:58 AM
sockr1
Oct 1, 2015 01:31 AM
Rachel Lu
Sep 27, 2015 09:53 AM
mv01
Sep 15, 2015 10:36 AM
