HeAT FROM Engine
Old Nov 15, 2010 | 07:37 AM
donny0391's Avatar
HeAT FROM Engine
Yesterday while driving for about 20 mins i smelt rubber burning and i had my ac off but hot air was still coming out of them .... does anyone know wat this could be ?
Old Nov 15, 2010 | 08:05 AM
pretty vague.
Old Nov 15, 2010 | 11:03 AM
geniusnouman's Avatar
do you mean hot air coming out of your vents? if you last had your climate control on heat (e.g. 75 fahrenheit) and is set on outside air mode, hot air still comes through vents while driving, even when the climate control is turned off.
for the rubber burning i'm not sure what that could be.
Old Nov 15, 2010 | 11:08 AM
donny0391's Avatar
thanks im not sure yet hope it wont happen again and yea thats wat i was trying to say
thanks
Old Nov 15, 2010 | 11:28 AM
VQPower37's Avatar
in order to stop heat coming in from the vents u have to turn on the recirculate mode ... the burning rubber smell ... not sure do u have an aftermarket electronics?
Old Nov 15, 2010 | 11:50 AM
nfnsquared's Avatar
PS hose?? What year TL? There was a safety recall for unprotected PS hoses melting/burn through causing fires in the engine compartment...
You can register at myacura.com to find out if the recall is applicable to your car. If it's applicable, the site will also tell you if it's been done on your car. Your dealer can also tell you this info...
Old Nov 15, 2010 | 12:14 PM
donny0391's Avatar
how do u put it in recirculate mode
Old Nov 15, 2010 | 12:16 PM
donny0391's Avatar
its a 2005 tl idk if its been recalled , but the PS hose is acting strange i hear a noise coming from it some1 said to get a new o-ring so ima try that out in a few hrs after wrk im goin right there
Old Nov 15, 2010 | 12:24 PM
blkaspec's Avatar
Full of water...
you press the recirculate button
its on the right hand side of the heating/cooling controls. I think its like the second one down from he top....there is a circular-ish arrow on the button. Its the thing that usually comes on when you try to Max cool the car. It will auto recirculate to help cool it quicker.
Old Nov 15, 2010 | 12:45 PM
donny0391's Avatar
thanks ill try that next time if it happens again
Old Nov 15, 2010 | 01:16 PM
nfnsquared's Avatar
...also fully explained in that little used, often forgotten book called: Owner's Manual
Old Nov 15, 2010 | 01:59 PM
I hate cars's Avatar
rockyboy
Aug 4, 2024 10:35 AM
01CLOwner
Oct 9, 2015 01:07 PM
Rachel Lu
Sep 27, 2015 09:53 AM
Sep 17, 2015 09:01 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
