Headlight questions
Old Mar 22, 2013 | 12:33 PM
V2subzero's Avatar
Headlight questions
I have an 04 TL A-spec and the driver side headlight seems to be working normaly, although the passenger seems to be working intermittently at about 20% working 80% of the time it wont turn on. I have taken the bumper off and I found a couple interesting things. I found a H.I.D controller, it doesn't seem to be stock? I unplugged both controllers and switched sides it gives me the same result, How ever when I unplugged it the driver side headlight and tired, it still came on as normal.
My theory is that the P.O had an aftermarket light kit and it started to mess up he went switched back to stock, and that's why the driver side will work regardless. I can not find a lot of info about the stock headlights on an 04, If some one can fill me in on any info I might need to know. Also, is that controller box stock? I think at this point I am going to switch the bulbs and see what happens. Lastly I see three areas on the headlight that will light up (corrner) (Projector) (Inside) neither of my inside lights will come on at all is this normal?
1. I found this H.I.D Controller
2. This is driver side turned on
3. Passenger side turned on
Old Mar 24, 2013 | 08:53 PM
ekxtreem's Avatar
try excanging the igniter, that most likely is the problem. i just did mine today, ebay has some oem ones for about $60.
Old Mar 24, 2013 | 08:59 PM
swoosh's Avatar
takin care of Business in
What I would really do is I would look into some stock ballast and igniter and swap them out....
but you can also swap bulbs and igniters and ballast from side to side, one at a time....if the problem follows, you found the culprit....if not then try the next item....
Old Mar 24, 2013 | 10:30 PM
cazio's Avatar
oops is that your face?
^^^^ agreed. u could always look into a used ballast and try that. I had a similar problem with my oem setup and it was just the ballast
Old Mar 24, 2013 | 10:46 PM
ekxtreem's Avatar
your ballasts are obviously good since you switched them and the right still works. take both headlight bodies off, that makes it much easier and u can plug in the wires with them off. switch the igniters, see if the driver side still comes on, if it does then switch the bulbs. u will need a fancy tool to take off the igniter and bulb covers, if u don't have one u can try a long nose pliers which worked for me. good luck!!
Old Mar 24, 2013 | 11:54 PM
V2subzero's Avatar
Did this and found the problem.
Old Mar 25, 2013 | 01:01 AM
ekxtreem's Avatar
BoricuaTL
Apr 8, 2016 01:08 PM
pistacio
Sep 26, 2015 09:45 AM
eastcoastguy
Sep 24, 2015 02:07 PM
datadr
Sep 12, 2015 09:12 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
