Headlight problem/unplugged wire?
Old Jan 29, 2018 | 02:59 PM
joe diego's Avatar
My driver side headlight went out, so I went ahead and replaced the bulb. Before starting I noticed there was a unplugged wire/cable. After replacing the bulb in the headlamp it still does not work. I noticed on the passenger side, that works fine, there is a buzz while on/working. On the driver side there is no Buzz sound.
Does anyone know where this plug goes? Is there another reason why my driver side light won’t work?
Old Jan 29, 2018 | 03:25 PM
input to ballast perhaps?
Old Jan 29, 2018 | 10:42 PM
joe diego's Avatar
Theres already is a plug going into the small box under head lamp. I think that’s the ballast. Thanks tho
Old Jan 30, 2018 | 01:02 AM
igloo's Avatar
Off topic, but, is that a non-sealed battery? As in one you can add fluid to?
Old Jan 30, 2018 | 01:33 AM
joe diego's Avatar
No
Old Jan 30, 2018 | 03:11 AM
mariusz439's Avatar
High/low beam perhaps.
Old Jan 31, 2018 | 06:03 PM
joe diego's Avatar
I checked the fuse in the engine bay for the driver side headlight and it was blown. I replace it with the proper fuse and it instantly blew once I turned the head lights on. This car is completely stock except for an air intake. Any help would be greatly appreciated. Thank you.
Old Jan 31, 2018 | 07:40 PM
peter6's Avatar
Unplug the balast, put new fuse, and turn headlights on.
If fuse is blown - short in the wire, look for damage somewhere
If fuse is not blown - balast is probably bad, make sure bulb is connected correctly.
Old Mar 9, 2018 | 01:36 PM
pepe lepew's Avatar
6th Gear
how did you get the fuse box apart? help please ......
Old Mar 9, 2018 | 09:50 PM
joe diego's Avatar
Just jiggle it around it’ll come off. Probably take about one minute. Very easy.
Old Mar 9, 2018 | 09:51 PM
joe diego's Avatar
Thank you so much for this. And help me solve my problem. You’re right.
PaHonda
Jul 20, 2011 06:16 PM
mr.b
Feb 18, 2011 05:55 PM
SilverG35
Apr 27, 2005 11:15 AM
