Headlight problem!!
Old Nov 21, 2008 | 02:16 PM
neutronics33's Avatar
Headlight problem!!
Hi guys,
So it started about a week ago, my driverside headlight HID beam turned purple! and then yesterday the light started flickering when it was on, it didn't completely go on and off but raipid flickering and one time all of the sudden it just turned off. I turned off the lights and turned it back on and it worked again.
Do you guys know what the problem is?
Also if i have to get a whole new HID set, how much is the Acura one compared to aftermarket? should i just go with a better aftermarket one?
I have a 04 TL so my warrenty is over, i'm not even sure if the warrenty would even cover HIDs.
Please let me know your thoughts!
Old Nov 21, 2008 | 02:30 PM
LoveMyTL-S's Avatar
Sounds like either the HID is going out or something is loose. Could be something simple. Have you looked at it yet?
Old Nov 21, 2008 | 09:52 PM
csmeance's Avatar
that means its a bad ballast for the HID. you can buy one from acura, and if you still have warranty it should be covered. If you do decide to get a whole kit, replace both bulbs since one will be bluer than the other since it colorshifted due to being used.
Old Dec 2, 2008 | 02:51 PM
luvmy05tl's Avatar
same thing happened to me it was just the bulb.
Old Dec 8, 2008 | 01:54 AM
That's definitely a ballast problem. I had BMW HID projectors and HIDs on my Legend, same thing happened to me a while back. Replaced the ballast, everything back to normal again.
Old Dec 8, 2008 | 02:16 PM
spc425's Avatar
I'm having the same issue. Driving my driverside HID would flicker and turn off. I'd park and leave the car. When I came back the light would be back on. So concensus is it's either the ballast or bulb? How much can I expect to pay for a ballast?
Old Dec 8, 2008 | 02:36 PM
I've seen used OEM ones go from $150 to $200 on ebay. There maybe aftermarket ones that would work, those would be cheaper, not sure which one works though.
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
MistaWet
Sep 15, 2015 08:26 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
