headlight output way too low and not far enough?
08 WDP TL-S
hi everyone,
After i tried to put some 6k bulbs on headlight,then i have this problem...my problem is my headlight output way too low and not far enough?hope everyone can help me out....
and after a day i switch back the stock one and the problem comes again?and i did bring to the dealer and check,but they said its normal?...because when i look some 3g opposite direction,it was so bright n far output enough,i realy have no idea why!
The higher numbers do not have as much output as the lower numbers. They also produce more glare for oncoming drivers.
If you had the same problem after switching back, they're probably just aimed too low. These HIDs are very sensitive to aiming since they are very intense and have a sharp cutoff point. Think about it for a second, we don't even have actual "brights", the reflector just changes the aim of the lights for brights.
You will need to re-adjust the headlights. Check the 3G Service Dept. on how to re-adjust them to factory specs. All you need is a wall, a measuring tape and a philips head screw-driver that's more than 7 inches long so you can to the screw
08 WDP TL-S
08 WDP TL-S
when i see on the wall is definitely look ok and good enough,but the point is when i drive i can see not bright,far,high and clear at all....especially when i drive,and i compare to other cars with stock projector HID
Registered Member
Registered Member
hi everyone,
That was what I meant but I didn't know the term for the flap. The real point being there is no extra bulb for brights and the intensity of the bulb does not change. If you've ever had them aimed even a little too high, people start flashing you quickly. They're not as forgiving as Halogens.
new bulbs need 50-100 hours of use to get their full brightness and color stabilized.
drive with them on all the time to get some `burn in` them
6ks are tougher to see by,,less actual white light in front of you
5s are nice compromise for us older folk with see'in problems--they pick out the road lines and signs better than stock does
stock is 4300
what brand bulb are you running?
if the car is lowered or the tires changed or maybe a 50 pound sub in the trunk??--that requires a reset of headlight aim
Nice of Acura to make it such an easy DIY--follow the groove~
stock is 4300
Registered Member
I re-aimed my '04 headlamps the first month I owned the car, taking them as high as I could without causing on-coming drivers to go nuts. Where I live, there are a bunch of 4-legged creatures running around and I want to see the, well in advance of hitting them and hurting my car.
I had to re-aim mine a week after purchase but I had to lower them. I installed subs in the trunk and that was alll it took to make it blind drivers. Sometimes I feel bad when I'm cresting a hill and I light up the inside of someone's car in front of me. Very worth it though. I don't think I could ever go back to regular lights again.
Registered Member
I had them on my last car; a 2002 Altima SE. I would look for them as an option (or standard equipment) on any new car purchase. For my '04 TL, I also installed 9006 Philips Premium lamps for my fogs. These give roughly 25-30% more light just in front of and to the front sides of the car. Perfect for our country roads where I live.
08 WDP TL-S
stock is 4300
stock is 4300
08 WDP TL-S
stock is 4300
stock is 4300
Registered Member
Yeah me, too. I want as much light projected out front that the law allows in order to avoid any 4-legged surprises - which we have a lot of where I am.
Registered Member
That's good to know about the foglamps. I will never convert mine to HID because I like the warm light from the halogens and it seems like they do a great job of showing detail. However, it would be nice to try that upgrade you're talking about to get a little extra light. They really make a difference on the country roads you talk about.
I have two 3G TL's. Mine has the Philips Premiums for its fogs and my wife's has the factory lamps. You can definitely see the difference between these two cars when using the fogs. She doesn't have a history of driving much at night so I have not replaced them as of yet.
I know it's slightly off-topic, but I was driving home Sunday night from a party in the GFs 06 Accord. A few months back, I had replaced the stock headlights with aftermarket projector units and a 5000K HID kit from DDM. Thank God I did, as one of our 4 legged friends decided to cross the Interstate right in front of me. Even though I had the cruise set to 70, I had enough time to brake and swerve to avoid a collision. Hell, I didn't even wake up the kids in the backseat! I did have to pull off at the next exit to let the adrenaline wind down.
HIDs > halogen
HIDs > halogen
anyone know the length from the ground up to where the hid outputs? since mine is a bit lower since i got my HID installed, and instead of adjusting it lower by 2.1 inches according to the manual just wondering what the right height should be. car is so far stock and inspection is this month too. ew
08 WDP TL-S
thanks, it was a random shot that and also where i parked it also haha, it was in the shaded area on a bright day and the overshadow makes it look oh so sexyyyy Need to clean it up a bit and reaim my lights so i can actually see some signs on the road then a SHOOT!
08 WDP TL-S
Very nice mankeep it clean lol......i really have no idea why my headlight look so cheap n not bright enough?and i did try to put 6k in,still look the same?
Ive read all the responding posts and I actually readjusted my headlights an hour ago and when i was driving back home, it didn't change much..i'm just looking for a solution since like the OP since I dont think he's satisfied with his headlights as well.
check, check and check.
i did readjust them myself. i did aim em a bit higher from what it was. i have HID Fogs too.
i think it's the ballast that is the problem...what do you guys think of replacing your OEM HID kit for an aftermarket one? is that not recommended? is that even possible to do? O_O i tried searching, but had no luck in that category..
try a different set of HID from another company like DDM or the one i got was a gift from Bavtoys? and its holding up fine, but recently i just re aimed them and it look soo much better because before it was just aim so low that it look odd till i finally re aim them higher probably by like 2-3 inches on each side. also recently got my inspection done and i had the guy look at where my headlights were to his chart thing on the wall and he said my passenger side is a tad high but its fine. so i know im 're aimed' but some of my friends have them pointed higher - but if its a ballast problem then HID wouldnt come on right?
AmplifiedDetails
09-24-2015 02:55 PM
