Headlight out...have questions.
LowNslowTL
I knowticed my drivers side headlight is out and i have a couple questions..
1.) what is the best replacement bulb? i figure ill do both
2.) how do i get to the bulb? do i have to remove the bumper??
3.) would it most likely be a burnt out bulb or do you think the ballast went bad? and is there a way to tell.
thanks for your help, this car is pissing me off
Its best to replace both at the same time. I like the OEM bulbs but there's tons of discussion here on others. https://acurazine.com/forums/3g-tl-2004-2008-93/diy-hid-bulb-change-w-o-bumper-removal-3g-garage-g-004-a-598853/
2. to do it right, take off bumper and headlights, dont be lazy.
LowNslowTL
update: i went out for a little bit in my buddies car, and i got a wild hair and turned on my headlights to make sure the light was still out.. and BEHOLD the light came back on? ballast going out? hopefully it was a fluke and im all good
HASTA LA VICTORIA'
Yea that's going to keep happening for bit until it goes out completely. I had the same issue last year changed out the ballast and bulb's but for some reason one of my lights keeps turning white after I bought the 6k ones.. So my advice is try the bulb's first since it's cheaper than the ballast. Bumper isn't that bad just the stupid plastic pieces break quick ..
BANNED
check out the morimoto 5k bulbs from theretrofitsource.com
i have those and love them. pure white.
MeelzJaw Auto Service
You will have to check. It will be either the ballast or the igniter. The igniter is literally the headlight socket. (assuming that power and ground are both present at the connector to the ballast)
If I didn't have Osram CBI, would've went with Morimoto 5k. Many good comments about it.
Taking out the bumper is totally waste of time, if you ask me. Could replace them by opening inner fenders (front of the tires)
Also can someone correct me on this. I know they are bulb too but does a xenon bulb go out directly like normal bulbs?
I experienced 2 bulbs going out but it happed slowly. First color turns the pinkish and then brightness goes down...
cipdagr3at, where did you buy the ballast?
Or anyone know how much is our stock oem ballast?
Just wanted to know
Just wanted to know
HASTA LA VICTORIA'
Just wanted to know
Just wanted to know
MEKO (02-02-2013)
sharksbreath or jon2000 can you post a picture of what the headlight color looks like. i currently have a headlight that has lost some color and will be replacing them soon. I was told to check out the morimoto's and was curious to see the color of the 5k, trying to figure out what ones to go with. 5k or 6k thanks!
Land of 10,000 lakes
Have you guys tried to order a set of HID bulbs from this vendor?
http://www.umnitza.com/philips-d2s-8...ir-p-5693.html
Our cars stock take 35w D2S bulbs. If you want 50w, you will have to get 50w bulbs along with 50w ballasts to accomodate.
I have a few more pics at: https://acurazine.com/forums/showthr...0#post14297610
Jon
Just did this last night and there is plenty of access if you pull the fender wall back. I also disconnected the battery for obvious reasons. One thing to note is that halogen housing unit has a torx 20 tamper proof screw, not a regular torx screw. The tamper proof screw has a pin in the middle. I was doing it in the garage late last night and until i put a flashlight on it i had no idea.
Back to the original post though, it sounds like your ballast.
emailnatec
29
09-28-2018 04:27 PM
AmplifiedDetails
09-24-2015 02:55 PM
