Headlight out
Old 07-07-2016 | 04:41 PM
Leoman08's Avatar
8th Gear
Headlight out
I replaced both headlights bulbs 6 months ago because the passenger side HID bulb was turning pinkish. Yesterday I noticed the drivers side headlight won’t turn on. I checked the fuses and there fine. Could this be a ballast or ignitor issue?
Old 07-07-2016 | 05:01 PM
yes. replace ballast
Old 07-07-2016 | 05:02 PM
DMZ's Avatar
DMZ
Head a da Family
Could be the ignitor also. The only sure fire way to find out is to replace one at a time and see which works.
Old 07-07-2016 | 05:08 PM
truonghthe's Avatar
check the igniter before replacing the ballast.
Old 07-07-2016 | 06:24 PM
WDPanda's Avatar
Are the left and right side parts interchangeable?
If so, you could just swap and check.
Old 07-07-2016 | 06:27 PM
they are.
Old 07-08-2016 | 08:21 AM
imakeholesinu's Avatar
If you have the time, patience and proper tools you can replace them on your own. On the drivers side you will encounter the cold air assembly that blocks the last two bolts to the headlight assembly. You'll need to remove bits of that before you can get to the those bolts. On the passenger side you have the wiper fluid bladder and pump partially blocking the last two bolts.
You can get an OEM Ballast and igniter off Amazon for $145.
Old 07-08-2016 | 08:57 AM
DMZ's Avatar
DMZ
Head a da Family
Check ebaY. There's actually good aftermarket ballasts on there for around $50.
Old 07-08-2016 | 08:58 AM
Good and aftermarket in this application don't go well together. The OEM Matsushita ballast is rock solid. I'm usually a fan of aftermarket (Morimoto) for other cars and retrofits but for the TL, I plan to stick with OEM)
Old 07-08-2016 | 09:05 AM
DMZ's Avatar
DMZ
Head a da Family
That of course is your choice, but I have an aftermarket ignitor installed for over a year now without any issues.
Old 07-18-2016 | 01:14 PM
Leoman08's Avatar
8th Gear
Does anyone have recommendations on where to buy ballast and igniter?
Old 07-19-2016 | 10:33 AM
https://www.amazon.com/Xenon-Ballast...dlight+ballast
https://www.amazon.com/Xenon-Ballast...CW9X2HXQZM0KF4
Old 07-19-2016 | 10:35 AM
OEM Acura TL 2008 HEADLIGHT parts
JJones91
10-17-2016 07:52 PM
Undying Dreams
09-19-2016 05:57 PM
nfnsquared
06-01-2016 08:13 PM
bentleyvtech
03-20-2016 09:23 AM
Mr. Showtime
03-18-2016 11:36 PM
