Headlight out
Old Jul 7, 2016 | 03:41 PM
Leoman08's Avatar
8th Gear
Headlight out
I replaced both headlights bulbs 6 months ago because the passenger side HID bulb was turning pinkish. Yesterday I noticed the drivers side headlight won’t turn on. I checked the fuses and there fine. Could this be a ballast or ignitor issue?
Old Jul 7, 2016 | 04:01 PM
yes. replace ballast
Old Jul 7, 2016 | 04:02 PM
DMZ's Avatar
DMZ
Head a da Family
Could be the ignitor also. The only sure fire way to find out is to replace one at a time and see which works.
Old Jul 7, 2016 | 04:08 PM
truonghthe's Avatar
check the igniter before replacing the ballast.
Old Jul 7, 2016 | 05:24 PM
WDPanda's Avatar
Are the left and right side parts interchangeable?
If so, you could just swap and check.
Old Jul 7, 2016 | 05:27 PM
they are.
Old Jul 8, 2016 | 07:21 AM
imakeholesinu's Avatar
If you have the time, patience and proper tools you can replace them on your own. On the drivers side you will encounter the cold air assembly that blocks the last two bolts to the headlight assembly. You'll need to remove bits of that before you can get to the those bolts. On the passenger side you have the wiper fluid bladder and pump partially blocking the last two bolts.
You can get an OEM Ballast and igniter off Amazon for $145.
Old Jul 8, 2016 | 07:57 AM
DMZ's Avatar
DMZ
Head a da Family
Check ebaY. There's actually good aftermarket ballasts on there for around $50.
Old Jul 8, 2016 | 07:58 AM
Good and aftermarket in this application don't go well together. The OEM Matsushita ballast is rock solid. I'm usually a fan of aftermarket (Morimoto) for other cars and retrofits but for the TL, I plan to stick with OEM)
Old Jul 8, 2016 | 08:05 AM
DMZ's Avatar
DMZ
Head a da Family
That of course is your choice, but I have an aftermarket ignitor installed for over a year now without any issues.
Old Jul 18, 2016 | 12:14 PM
Leoman08's Avatar
8th Gear
Does anyone have recommendations on where to buy ballast and igniter?
Old Jul 19, 2016 | 09:33 AM
https://www.amazon.com/Xenon-Ballast...dlight+ballast
https://www.amazon.com/Xenon-Ballast...CW9X2HXQZM0KF4
Old Jul 19, 2016 | 09:35 AM
OEM Acura TL 2008 HEADLIGHT parts
JJones91
Oct 17, 2016 06:52 PM
Undying Dreams
Sep 19, 2016 04:57 PM
nfnsquared
Jun 1, 2016 07:13 PM
bentleyvtech
Mar 20, 2016 08:23 AM
Mr. Showtime
Mar 18, 2016 10:36 PM
