headlight help!
Old Sep 3, 2009 | 03:55 PM
jdubub's Avatar
Question headlight help!
my headlights keep getting that hazey nasty look on them. twice in the past year i have taken them to get them clean. but they are getting hazey again! anyone know of a permanent fix? without having to just go buy new lights? is there a place that will trade with cash??
Old Sep 3, 2009 | 06:11 PM
01tl4tl's Avatar
outside haze you can diy with a drill and a special plastic polish and buffer wheel
If its getting inside,, the seal on the lens is leaking water in- which will drip down onto the ballast killing it
There was someone swapping out housings for $, search the threads, or check Garage section for DIY
Old Sep 3, 2009 | 06:27 PM
LoveMyTL-S's Avatar
Give JnC a PM. He does custom headlights and I believe uses a swap program.
Old Sep 3, 2009 | 06:39 PM
nate_0022's Avatar
Land of 10,000 lakes
I don't believe there is a PERMANENT fix. This is just something that happens to the plastic lenses due to the elements and UV.
Old Sep 3, 2009 | 09:52 PM
csmeance's Avatar
there is! Wetsand and polish the headlights to a perfect finish, then cover it using some 3M clear-bra and it'll protect the plastic from hazing over!
Old Sep 4, 2009 | 06:56 AM
voigt's Avatar
If it is outside there is a fix. I do this to headlights all the time. Start with an 800 grit sand paper and wet sand the headlight, then move to a 1000 and spend twice the time wet sanding, lastly finish with 2000 grit sanding at twice the time of the 1000. Now you should have barley noticeable scratches. Always sand in one direction. Then get some 3M rubbing compound and follow directions. This will take out the fine scratches. Then I finish with Maguiers Plastix. If you don't know how to wet sand find someone who does.
Before
After
Old Sep 4, 2009 | 06:57 AM
voigt's Avatar
oh be sure to tape any paint, or better yet remove your headlights
Old Sep 4, 2009 | 07:19 AM
JnC's Avatar
JnC
Former Sponsor
+1, reason why the haze keeps coming over is because the protective clear coat that comes on the lenses form factory is gone from all the buffing. Once that goes the lenses oxidize very very quickly.
If your problem is only hazing then just buff them with a buffer and some PlastX, once you achieve the desired shine and clarity cover the headlights with 3M clear bra, do not use anything else then the clear bra as other products tend to use adhesive that interacts with the plaxy glass lenses and causes spider webbing.
Although I do offer swap options but its only for OEM condition headlights
Old Sep 4, 2009 | 09:07 AM
chapu08's Avatar
Don't waste your time and $$ w generic products, like me. Coordinate w JnC to send your headlights. If I can turn back time I will do that. Too bad I can't
Old Sep 4, 2009 | 06:32 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
The better alternative imo is to re-clear the lens with high quality, high solids 2K clear coat. You don't have to worry about it afterward, and it will look great.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
