Clutch Issues
Old Sep 4, 2009 | 04:04 PM
Slobodan's Avatar
Clutch Issues
I have an 06 6speed MT
I'm running into a problem after driving aggressively for a few minutes running the gears up to 6,000rpm or more.. i slightly depress the clutch and it seems really hard to push the clutch in.... i spoke with a guy at the dealership and he beleives that the clutch is getting ready to go? Is there anything i can do to change the clutch fluid? anyone know how to do that???
Old Sep 4, 2009 | 04:11 PM
TimTim's Avatar
RETIRED
I'm not sure if i'm correct, but usually signs of slippage in your clutch would be signs of it ready to go. But It sounds like you just need some clutch fluid. Check the manual. Take pictures if you can, I need to do the same eventually.
Old Sep 5, 2009 | 12:43 PM
AcuraTLRob's Avatar
7th Gear
Clutch Master Cylinder
It may also be that the clutch master cylinder is failing. I went through 3 under warranty. You might want to check the fluid level first before installing a new clutch. The Acural uses brake fluid in the clutch master cylinder. It is located under the air box on the drivers side.
mugen_kid
Nov 13, 2015 10:38 PM
carz0159
Sep 20, 2015 06:11 PM
Skirmich
Sep 19, 2015 04:16 PM
TxRzrBk
Sep 17, 2015 01:07 PM
heyitsvic
Sep 4, 2015 09:38 AM
