Headlight condensation problem
Old Jul 2, 2011 | 03:28 PM
vincentbesner's Avatar
i have a black 04 acura tl and i recently got in a small fender bender, nothing big. since then my headlight has had condensation in it, im not sure if its cracked or not but any help would be awesome.
bad side
good side
both sides
any help would be awesome as to how to fix it.
Old Jul 2, 2011 | 03:30 PM
ive tried to buff it out and use different products but nothing has worked
Old Jul 3, 2011 | 08:05 AM
71Chally's Avatar
The housing is cracked and thus allowing water in. It will sit there and obstruct the headlights function. If enough gets in, it will lead to corrosion in the light and wiring. You will have to replace it. By an Acura part, most of the aftermarket lenses do not have a quality hardcoat and will haze over in a year or two.
Astrobuf
Old Jul 3, 2011 | 09:00 AM
thanks, do you know if it is possible to purchase the lens by itself without having to buy a whole new headlight?
Old Jul 4, 2011 | 09:29 AM
71Chally's Avatar
Rockauto has two suppliers headlight assembly's (no lamp/ballast, just the plastic bits) for about $280 each. I'm not sure how much an Acura part would be, but I'd guess about $600 each.
Personally, I'd opt to find a junk yard part. That way you'll get an Acura part for ~ $100 You might have to hunt a bit.
71Chally
Old Jul 4, 2011 | 02:06 PM
paperboy42190's Avatar
is it just me or does that not look like condensation. looks like a very hazy and un-taken care of headlight.
Old Jul 4, 2011 | 10:16 PM
i can almost guarantee you its cracked beacuse i noticed this the day after my car got hit. hard to find a 3g tl in a junkyard around here ive looked
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
MistaWet
Sep 15, 2015 08:26 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
