Headlight condensation problem
i have a black 04 acura tl and i recently got in a small fender bender, nothing big. since then my headlight has had condensation in it, im not sure if its cracked or not but any help would be awesome.
bad side
good side
both sides
any help would be awesome as to how to fix it.
bad side
good side
both sides
The housing is cracked and thus allowing water in. It will sit there and obstruct the headlights function. If enough gets in, it will lead to corrosion in the light and wiring. You will have to replace it. By an Acura part, most of the aftermarket lenses do not have a quality hardcoat and will haze over in a year or two.
Astrobuf
Astrobuf
Rockauto has two suppliers headlight assembly's (no lamp/ballast, just the plastic bits) for about $280 each. I'm not sure how much an Acura part would be, but I'd guess about $600 each.
Personally, I'd opt to find a junk yard part. That way you'll get an Acura part for ~ $100 You might have to hunt a bit.
71Chally
71Chally
tman570
Jun 11, 2019 07:56 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
