Head light problems please help
Old Jul 17, 2011 | 05:46 PM
juan.vargasromero's Avatar
so yesterday i noticed that my right head light would not turn on. i was not awear that my 2004 TL had two differnet bulbs for low and high. well the low and high dont turn on so i figuerd it could not be both bulbs that where out. so i found out that my fuse for my low beams did not was blow, i replaced it and it blew it out again. so something is shorting out causing my fuse to blow. so what could be causing my low and high beams not to turn on and blow my fuse.
Old Jul 17, 2011 | 05:52 PM
guitarplayer16's Avatar
There's only one bulb for low and high beam.
We have bi-xenon projectors...
That being said, means that there's a motorized "shield" that moves to enable high beam, using the same bulb to output light.
Old Jul 18, 2011 | 01:29 AM
mrlal8's Avatar
this problem happened to my friend about a year ago. We were confused at first...he kept changing fuses and they kept blowing. Then is started happening to the other headlights...Turns out that it was a problem with the ballasts. He changed both ballasts and everything worked afterwards
Old Jul 18, 2011 | 07:25 AM
SouthernBoy's Avatar
Registered Member
The '04 TL not only has just one headlamp for each side, but these lamps are not low or high beam. The 3G TL does not have low or high beam lamps at all. It makes up of a mechanically operated "flap" that controls the amount of light allowed to exit the enclosure.
We have HID headlamps (High Intensity Discharge). These make use of a ballast which may in your case, have failed. This needs to be checked out.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
Ny1718
Sep 11, 2015 09:21 AM
