Hazes on Headlights are developing!
Old Dec 14, 2009 | 10:05 PM
dbqkqh's Avatar
Oh snap.... my headlights are developing hazes over them, so far it is minor.
Anyone know of any DIY to remove the hazes, if possible?
It is starting to look bad up close.
Or the only option is to replace them?
Old Dec 14, 2009 | 10:48 PM
handsom-hustla's Avatar
there may/should be a diy on here. or u can google it. you don't need a diy specific for the tl. my brother had a similar problem my dad had some aceton stuff in his work truck. worked wonders.. heres a little something i picked up on google:
  1. Recognize that the problem is caused because the outside cover is oxidized and needs the outside surface polished to be clear again.
  2. Wash the outside of the lights with soap and water as you would when washing the rest of your car. Dry. This step will remove the grime and dirt before you start polishing.
  3. Apply an aluminum polishing compound with a dry soft cloth. Put a little compound on it and work it on in small circular motions. Let it dry to a haze. Now, buff the haze off by wiping with a clean towel or cloth.
  4. Repeat the polish and buff steps until clear again. It may need 3 coats or more.
there is other compounds u can use. hope this gives u a start.
Old Dec 14, 2009 | 10:55 PM
TheChamp531's Avatar
Chapter Leader (San Antonio)
https://acurazine.com/forums/3g-tl-2004-2008-93/g-085-diy-restoring-hazed-cloudy-headlights-710313/
No problem.
Old Dec 15, 2009 | 12:28 AM
01tl4tl's Avatar
$10 DIY kits with a foam buffing ball or disc and some special plastic polishing compound
When done wax them to cut down on the problem
Old Dec 15, 2009 | 08:57 PM
Amewz_Ack's Avatar
Wow!i love AZ.. i've been meaning to do this with the DIY from Autozone, until i read that you can use aluminum polishing compond... so i remembered i had some, and to my surprise it WORKED!!!
Old Dec 15, 2009 | 09:54 PM
dbqkqh's Avatar
Hm, that's good to hear, going to look into that :P
Old Dec 16, 2009 | 08:11 PM
jdmintegra00's Avatar
is this when the headlights start loosing how clear they are?
Old Dec 16, 2009 | 10:08 PM
MiataNut's Avatar
For this I always use Mequiars Cleaner Wax (maroon bottle) with a terry towel. The reason it works is there is a very mild abrasive in it, this is why it's also good for scuffs from door dings, etc.
Guy at work literally drug half his rear door and rear 1/4 panel along the side of his garage ('04 graphite Accord EXL V6) and it looked REALLY bad - just white smears all over from the siding & trim. I offered to hit it with the MCW and I swear, I wish I had taken before & after pics - it's almost totally perfect again. Even the body color side molding, which I thought was toast, seemed to be ground into it, but nope - cleaned & shined that too.
I love this stuff! (sorry to sound like an ad )
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
