Has anyone used the 07-08 BAYA
Old Dec 7, 2019 | 02:04 PM
19Ralph93's Avatar
I was driving my 05 TL and the CEL went off P0700 P0723 P0848 P0873 ive been referred to the baya but alot of thoes people never used it? Thanks in advance
Old Dec 7, 2019 | 03:24 PM
csmeance's Avatar
07-08 TL is a different transmission, I think it uses 3 or 4 shafts vs the 2/3 that the 04-06 trans uses. Some folks swap out to accord V6 trans.
Old Dec 7, 2019 | 04:51 PM
horseshoez's Avatar
Latent car nut
I think you are confusing your transmissions, I believe the only BAYA transmissions come out of 2006-2007 V6 Accords; the 2008 transmissions will not bolt up to your engine as they have a different mounting plane.
Old Dec 8, 2019 | 10:32 PM
19Ralph93's Avatar
so what would you recommend for a 3rd gen 05 TL?
Old Dec 8, 2019 | 10:33 PM
19Ralph93's Avatar
Old Dec 8, 2019 | 10:41 PM
horseshoez's Avatar
Latent car nut
I would recommend the same thing virtually everybody else around here recommends, a BAYA transmission from a 2006-2007 Honda Accord V6. If you search this site you will find many threads on the subject.
Old Dec 10, 2019 | 09:49 AM
t-rd's Avatar
If you want to swap in an 06-07 AV6 BAYA trans then you need to have a trans shop do the valve body mod using translab shift kit to widen the valve body channels with higher tension springs. The OEM valve body has a design flaw that allowed the trans fluid to seep through and overheat the torque converter. I've already done a trans rebuild on my 07 AV6 so I'm aware of this.
alan_rich
14
Nov 23, 2016 01:14 AM
vinuneuro
Jan 23, 2014 01:54 PM
kgovett
Mar 25, 2013 12:51 AM
track 1
Aug 1, 2009 02:14 PM
njfinest05
Jan 24, 2009 10:42 AM
