Has anyone had the Outside Temp Display go flatline?
Old Apr 29, 2007 | 05:15 PM
  #41
mjfpjf's Avatar
mjfpjf
Mine went flatline yesterday afternoon while in traffic on a Phoenix expressway. Reset itself and seems to be working fine today.
Old Apr 29, 2007 | 08:10 PM
  #42
6spMike's Avatar
Mike's Silver Bullet
It'll flatline above 115 degrees, someone said in a post quite a while ago.
Mine flatlines in Tucson kind of regularly in summer.
Old May 12, 2007 | 11:09 PM
  #43
mjfpjf's Avatar
mjfpjf
Unhappy Flatlined ... again
My temp read-out went flatline this afternoon and temp was only about a 100.
When it came back on, it was stuck at 90 even though I know the temp was higher. Also since it flatlined three weeks ago, it seems to respond very slowly. I back out of the garage in the morning with the read-out at 80 and temp is 65 ... it takes five minutes or more to reach 65. Anybody had this? Time for fuse 7? Time for the dealer?
Thanks in advance
Old May 13, 2007 | 01:04 AM
  #44
6spMike's Avatar
How long does it flatline for?
A few seconds on startup is what mine does.
There's a pretty sophisticated algorithm that it uses that sometimes gives different readings than what you expect; it has to do with coolant temp and how far/fast you have driven the car; it takes a while to change because the algorithm it trying to make sure the reading isn't affected by engine bay heat. It'll always flatline above 115 degrees.
In traffic, the temp could be 115. It was 105 in Tucson today.
What you are describing sounds like normal operation to me.
Couldn't be the fuse; it wouldn't work at all.
...Take it in if it bugs you.
...If you take it back to IL it'll be fine. Sorry, I couldn't resist.
Old Nov 22, 2021 | 08:48 AM
  #45
Going4Five's Avatar
Outside temp gauge flatlined
I just had this issue occur. I located the sender behind the bumper, and it was physically undamaged.
I read pulling fuse #7 and/or fuse 21, might solve it-no go.
On a hunch, I pulled fuse #5 (another 7.5 amp fuse), for a few seconds, and I am back in business.
Perhaps I am misteading the fuse # key on the fuse block cover, but I pulled#7, and then # 5, and # 5 was the winner.
ITSJESTER
17
Dec 6, 2018 02:29 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Jboat
Sep 30, 2015 10:58 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
Froid
Sep 27, 2015 06:16 PM
