Hard to shift in gear ('07 TL Type S)
So I just had my clutch replaced. When I picked it up from the shop it drove fine, minus it being super sensitive because it still needs to be broken in.
The next day I noticed I had a hard time getting in to certain gears, especially 1st/2nd and Reverse.
I've read about similar issues and some were suggesting clutch bleed, MTF flush. Also I haven't quite broken in my clutch yet.
I actually replaced my Master and Slave cylinder before I got my clutch replaced thinking that these could be the culprit of prior problems I had which led me to replace my clutch.
Any input? Thanks all.
And yes, it does help when I double (sometimes triple) pump the clutch and hold the clutch pedal down briefly before I get it in to gear. When shifting when I'm already in gear I have also been noticing that it's not disengaging and I need to let off the clutch, gas again, then clutch before I can get it in to neutral.
Thanks all for the replies.
I took it back this morning to the shop where I got the clutch installed, picked it up shortly after with the clutch pedal adjusted. Apparently it was sitting too low which may have caused the hydraulic system to not fully engage and disengage. I'm going to drive it around a bit and see if it's still fine after I break the clutch in. I really appreciate the help!
sockr1
Oct 1, 2015 01:31 AM
Mike Bertram
Sep 10, 2015 09:27 AM
