handling isuue
handling isuue
i have a 05 tl 6 speed, steering wheel feels light and loose, felt like it has no pressure holding on to the steering. when going over bumpy roads and grooves, it twitches pretty hard to the left and right, alot of feedback from the wheel to the steering, especially on uneven pavement, it just follows the road imperfection
is this a common problem?
here's some works i have done: suspensions, 6 front lower control arm bushings, 2 rear control arms, tires and rims, alignment, no improvement, if anyone here is having the same issue or might know the solution to this, please help~
thanks for the response, yes i did check the power steering fluid from time to time, it looks fine with no leaking or anything, power steering hose recall was done a week ago, but no improvement with handling
can you get the alignment specs that the car currently has? (they put it on the machine and it tells you the alignment settings that it currently has, and what the acceptable range should be. It's a printout they give you. Also what tires are on the car? Air pressure? Miles on them?
alignment setting for toes are .02 front and .07 rear which is within factory spec range, rear right camber is -1.8 off by .03 (factory spec -1.5) which is the only thing "red" showing on the reciept
i was running on stock tires rims and suspension when i had this problem, i thought it was the rims and tires or suspension causing the bad handling so i went and changed them all, i even changed all front 6 bushings for the front lower control arms and 2 rear control arms before doing the alignment, problem still exist.....
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
