Green Flashing Key Issue
Old Aug 21, 2013 | 02:36 PM
AcuraTLColts's Avatar
Question Green Flashing Key Issue
My wife and I were out on Sunday and came out of a store to head home and our 2006 Acura TL would not start. I noticed a green flashing key on the instrument panel. I tried our other set of keys and the same thing happened. We looked online and have found it is an issue with the transponder key not communicating with the immobilization feature on the vehicle. I have seen posts that have referred people to the dealer to fix and I have seen posts that mention using a locksmith to reset the transponder key to the immobilizer unit. Can anyone provide some guidance on this issue? If I go to Acura I am going to have to pay for the tow, pay to have the diagnostic done and pay for parts and labor potentially. If I use a locksmith and that works, they will come to me and the fee will be less than having a diagnostic done. I just don't want to go to a locksmith and have it work for a few days and then have to go to the dealer anyway...Help
Old Aug 21, 2013 | 04:23 PM
profuse007's Avatar
Flashing can mean several things but simply the computer say it's the wrong key.
To isolate the problem, make sure to stick in only the Acura key. If you have other electronic components on the keychain, it may have a false reading.
You don't need to make attempt to start the car to know it will work or not, just turn the key to III position (aka ignition position) and see. It will attempt to "handshake" the code reading; blinking is wrong and solid is right. The solid light will go away after it handshakes.
Very weird issue. Second time hearing about it but first with Honda. There are tools out there to read, reprogram/relearn the transponder but you might not have enough time.
If you call a locksmith, ask if he's able to read your vehicle's transponder. The software is called Honda Diagnostic System (HDS), btw.
Old Aug 21, 2013 | 04:37 PM
losiglow's Avatar
I've had this problem but only with my grey valet key. My two 'black' keys work fine. Good luck with the problem man. Sounds expensive
Old Aug 21, 2013 | 04:54 PM
profuse007's Avatar
No it should not be expensive. The reading of the code takes less than 1 min to do. I know I have the tool.
Old Aug 22, 2013 | 01:53 AM
carz0159's Avatar
I heard about the issue not to long ago, a clogged ac line dripped on to the part of the ecu, causing a short, and it wouldnt take any keys.
rockyboy
Aug 4, 2024 10:35 AM
ibGTV
Sep 28, 2015 03:40 AM
PortlandRL
Sep 14, 2015 12:01 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
HeloDown
Sep 8, 2015 06:51 PM
