gear selector / console Bulb?
Old May 3, 2010 | 10:36 AM
ajs800's Avatar
I searched and checked out the garage but I did not find anything regarding replacing the gear selector bulb. once the console is removed, how do you remove the actual selector indicator where the bulb is located? Is it possible to replace the bulb without removing selector indicator trim (#12)?
Old May 3, 2010 | 03:15 PM
nalek's Avatar
Yes, it is possible. I had it torn down this weekend to find a rattle from the shift lock. The bulb is on the driver side of #12 shown. However, removing 12 is very easy once you get to where you need to be to replace it. 12 just has 4 clips and lifts easily off the shifter assembly
You need to remove the carbon fiber/wood panel around the shifter, and from there, the bulb is very easy to see/replace.
http://i43.tinypic.com/2yxejh2.jpg
http://i42.tinypic.com/nxnbc5.jpg
There might be an easier way to get to it, but from what I saw while digging.. I cant imagine how.
Old May 3, 2010 | 03:52 PM
ajs800's Avatar
yours seem to be a little different being an '07, but I'm sure it's the same process. I plan to remove the console and replace my navi button bulbs, so i will do this at the same time. I can remove #14 very easily and get right to #12, but I don't think #12 can be lifted without removing the console.
Thanks for the info.
hashbrown
Feb 18, 2022 11:20 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
