Gas pump constantly shutting off...
Old Dec 4, 2011 | 09:50 PM
e5c4p3artist's Avatar
I've had this problem for awhile, but haven't taken the time to diagnose it. Now that it's colder out, it is more inconvenient.
I have a 2004 TL. When I gas up, the gas pump keeps kicking off every 5-10 seconds. I basically have to keep squeezing and unsqueezing the handle for the entire fill-up.
The car runs fine, but do you think there is some kind of blockage in the gas tank? Something causing gas to splash back up and signal the pump to shut off prematurely?
As a side note, and perhaps unrelated but worth mentioning, the float that tells how full the gas tank is reads off a little. When the car is completely full, the needle is indeed on "F" but it leaves the "F" quickly - within 25 miles of driving. And when the computer tells me I have 1 mile until empty, I have driven up to 80 miles further and even then, when I filled the tank, it only took fewer than 15 gallons to fill.
Old Dec 4, 2011 | 11:15 PM
gwiffer's Avatar
Does this happen at different stations/pumps?
Old Dec 4, 2011 | 11:21 PM
Bearcat94's Avatar
AZ Community Team
Nope, not really worth mentioning.
It's totally, 100% normal. Everyone's does this. It's the design. Basically there is a "reserve" of about 3 gallons.
Links to several useful threads on this specific issue in this list of FAQ/DIY topics: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
Old Dec 5, 2011 | 08:36 AM
06NH6MTTL's Avatar
just so you know if this is happening at every gas station you fill up it is not normal. It means the evap charcoal canister is full of fuel from over filling. you will need to replace the canister because it is now contaminated!!!
Old Dec 5, 2011 | 10:33 AM
ez12a's Avatar
the overexplainer
yea something's clogged if it's happening all the time. It should only kick off when full but to fill the tank from empty by constantly squeezing the lever isnt normal.
Old Dec 7, 2011 | 11:25 PM
It is indeed happening at every gas station. I have never heard of the evap charcoal canister. I will do some research on that. If anyone else has input or advice, I always listen to it!
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
San Yasin
Sep 29, 2015 10:52 AM
